Author: Subject: Fuel economy up by 50% !!!
Hector.Brocklebank
posted on 21/5/12 at 06:24 PM Reply With Quote
Discuss.....
Fuel Economy Enhancement
Some people can never handle the truth and always try to shoot the messenger instead of taking an honest look in the mirror (its always easier to blame another than to face reality), but secretly they wish they could grow a pair and be the messenger !!!
designer
posted on 21/5/12 at 06:56 PM Reply With Quote
Apparently, the engine is a new 'concept', so what are they claiming the 50% improvement against?
blakep82
posted on 21/5/12 at 07:01 PM Reply With Quote
According to MIT’s Technology Review, such an engine has the potential to increase the fuel economy of gasoline-powered cars by 50 percent
something of equivalent size/power i guess
as per usual the figures won't really match up, same with any marketing guff these days, however, since its delphi that are working on it, i think its a bit more reliable than the usual hydrogen water electrolysis nonsense that usualy comes up.
i'm looking forward to laser 'spark' plugs being everywhere, not sure if there's much of a economy benefit, but i like lasers...
________________________
Simon
There has been talk of dieselling petrol engines for quite some time.
Simon
Over a conventional spark ignition engine.
mcerd1
posted on 21/5/12 at 07:51 PM Reply With Quote
the claims arn't as impressive, but I recon this one looks like it has some real potential:
http://www.ilmor.co.uk/concept_5-stroke_1.php
Ninehigh
posted on 21/5/12 at 08:03 PM Reply With Quote
Interesting.. would be good to see some kind of real world comparison too.
Also have that kind of engine powering an electric motor Ampera style...
posted on 21/5/12 at 08:27 PM Reply With Quote
dont believe it myself. I cant see how using a spark plug is so hugely inefficient compared to their system, considering that their engine sounds basically the same as a normal engine. Audis FSI already does fancy stuff with the fuel delivery so its not like anything else about their system is totally unique.
Not that IC engines arent hugely inefficient though, so im sure there is room to use more energy from the fuel. But this idea doesnt seem novel enough. Maybe if they could make something like a fuel cell that reacted petrol at a catalytic surface, that would seem a new enough approach to make huge improvements, but not some replacement for spark plugs.
mcerd1
posted on 21/5/12 at 09:08 PM Reply With Quote
its all down to thermodynamics (not sure I beleve the 50% though) its main reason that diesel is more efficent than petrol
the Otto cycle that spark ignition engines are based on is inhernetly less efficent than comression ignition diesel cycle engines even in a perfect world with no unwanted friction etc....
(I would go and open up my old thremodynamics books to get the details but they give me nightmares )
[Edited on 21/5/2012 by mcerd1]
posted on 21/5/12 at 11:48 PM Reply With Quote
Compression ignition means you run very high compression ratios, like a conventional diesel engine. The thermal efficiency of a four stroke engine is related to it's compression ratio, so the more the batter, but with spark ignition you are limited to a relatively low value by the fuel octane.
FSi/GDi etc is a very small evolutionary step from port injection, and provides relatively small benefits (and quite a few of it's own problems). A compression ignition petrol engine is a very different thing and is a significant step up in terms of benefits and technical challenges.
[Edited on 21/5/12 by MikeRJ]
hughpinder
posted on 22/5/12 at 07:17 AM Reply With Quote
I guess its possible that you could get "50% increase" in efficiency for a non turbo petrol engine. It has a maximum thermodynamic efficiency of about 40%. An engine running the diesel cycle is about 50% thermodynamic efficiency, so 40% to 50% is a "25% increase". If you add in heat recovery like in the elsbett engine (oil cooled with no radiator - If you remember many years ago top gear drove a merc running on veg oil that had one of these engine and did about 60mpg while giving better power and torque). I suspect if you combined both of these you could get to 60% thermodynamic efficiency. I thought the main problem with running a diesel cycle with petrol was pre-ignition of the fuel (pinking), and I wonder what they've done to overcome it.
Hugh
coyoteboy
posted on 22/5/12 at 12:31 PM Reply With Quote
You'd be lucky to see a real world engine with 50% overall efficiency , you'd be lucky to see it with 40% in any point other than one specific operating regime. Power station turbines are some of the most finely tuned and super-efficient machines available and they only manage ~44% in real world conditions and overall you're limited by carnot anyway. I think some humongous 2 strokes manage super-high efficiency but generally 4 strokes suffer inherently due to additional movements with no power output.
The points above are correct - diesels get higher efficiency due to their higher compression ratio which can't be achieved normally with a petrol engine due to uncontrolled detonation. Direct in-cyl injection allows you to control when the fuel enters and how meaning it can enter a scenario that would normally mean it would have detonated long ago and then effectively be sprayed in like a flame thrower creating a long smooth burn instead of a single blammo that bends rods.
However it's really hard to get these timings and quantities right over a range of loads and once you have reached the CR of a diesel you can't "abort" and run as normal if for example you find idling this way difficult, you have to run CI all the time.
[Edited on 22/5/12 by coyoteboy]
mcerd1
posted on 22/5/12 at 12:57 PM Reply With Quote
the latest and greatest ones are claiming 55%-60% (according to the folk who run them)
but think they are mostly the super critical steam combined cycle ones
Stirling engines have a better theoretical efficency but have never been made pratical after more than 100 years of atempts...
[Edited on 22/5/2012 by mcerd1]
coyoteboy
posted on 22/5/12 at 01:55 PM Reply With Quote
Yep, some of the huge ones with combined cycles do indeed make that sort of range. However the current power station operating regime plans I have in front of me quote 44% on a supercrit with reheat.
Indeed they do but I know to my pain that they're very hard to create, primarily for materials reasons. There are, however, hundreds of operational stirlings out there but they rarely make more than about 25-30% efficiency. Most of them are in heliostats in the deserts of the US and spain. however they're now being introduced into domestic microCHP with reasonable technical success, if not financial at this stage.
http://www.whispergen.com/content/library/whispergen.html
