Macbeast
posted on 25/7/12 at 08:14 PM |
Someone will know
53 Ford Focus, 1.8 Zetec.
When I pull up, at traffic lights say, come off the accelerator and step on the clutch the engine speed rises from the normal 800 rpm to about 1500.
After 2-3 secs, it settles back down to the normal 800 rpm.
Only just started doing this. Any ideas why ?
flibble
| posted on 25/7/12 at 08:41 PM |
sticky iac valve?
tomgregory2000
| posted on 25/7/12 at 09:25 PM |
Broken
Simples
Macbeast
| posted on 25/7/12 at 10:56 PM |
Great.
err
What's an IAC valve ?
RK
| posted on 25/7/12 at 11:05 PM |
Idle Air Control
Tiger Super Six
| posted on 26/7/12 at 10:03 AM |
I had an Escort 1.8 Si in 1997 and it did the same thing, never sorted the problem!
Mark
Tiger Avon
Davegtst
| posted on 26/7/12 at 10:55 AM |
There used to be a few of these causing problems when i worked for Ford. You can try unbolting the idle valve and giving it a good clean out with
some carb cleaner. That usually sorted the problem.
Bluemoon
| posted on 26/7/12 at 11:46 AM |
Had the same problem on our Fiesta (cross flow derived engine), uses the same IAC as the zetec, tried cleaning with carb cleaner still not working;
ended up replacing it.. Ours had got stuck open a bit and would over rev all the time.
Come to think off it it showed symptoms like you describe before failing, thought it was a sticky throttle cable.. Once it failed with what amounts to
an air leak as so large it was almost un-drivable; In a 7 think it's going to be a brown trouser moment..
[Edited on 26/7/12 by Bluemoon]
mcerd1
| posted on 26/7/12 at 12:39 PM |
had the same issue on my 1.8 focus (Y reg) - it was just a massive Vac. leak from a split breather pipe
it was this one in mine, goes round the back of the head and is very hard to see without removing the air intake etc...
  breather pipe
[Edited on 26/7/2012 by mcerd1]
Macbeast
| posted on 26/7/12 at 05:25 PM |
OK guys. Thank you all very much.
Checked Haynes for IAC valve and it says on the 1.8 it's behind the inlet manifold and VERY difficult to access
Deep joy. so what's new ?
mcerd1
| posted on 26/7/12 at 06:42 PM |
you can see it once the plastic intake pipe comes off - from memory all you need to do is unplug the mass flow sensor, unbolt the air filter top and
remove the jublee clip from the throttle body - you should be able to see it after that
you don't want to touch the manifold or throttle body itself, because then you'll need new gaskets
UncleFista
| posted on 26/7/12 at 09:28 PM |
If it's the one under the plastic inlet manifold, it's a pain but quite doable by feel.
Tony Bond / UncleFista
