Author: Subject: Found it
madteg
posted on 12/8/12 at 02:18 PM Reply With Quote
Found it
Spent 3 weeks looking for a problem, When hitting about 150KPA on boost car suddenly going weak (17.5). Checked ECU Map sensor, seamed OK, changed fuel regulator. Removed inlet manifold to find a split accross the underneath of the air box. Now welded up JOB DONE.
NeilP
posted on 12/8/12 at 04:09 PM Reply With Quote
So basically Kev, your turbo blew a hole in your intake
Let the madness re-commence...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
madteg
posted on 12/8/12 at 04:10 PM Reply With Quote
Yep, trust it to be where i could not see it.
posted on 12/8/12 at 05:45 PM Reply With Quote
Glad you got it sorted Kev . One of the smoke machines would have found it in seconds but at about £700 you'd have to use it a lot to justify the cost. Anyone know a locost way of making one?
DIY Si
posted on 12/8/12 at 09:03 PM Reply With Quote
Gas testing smoke bomb in a box and a low pressure air line connected to a compressor and the inlet?
Sun Tzu, The Art of War
