Author: Subject: not seen this done before
posted on 9/11/12 at 08:08 PM Reply With Quote
you have to be pretty brave when getting the hack saw ..... (pic is linky)
Works Mini Cooper S MK1 Mk2 Split Weber 45 DCOE Special Tuning Works Longman | eBay
steve m
posted on 9/11/12 at 08:11 PM Reply With Quote
OMG
what a waste of a good.........................hacksaw blade
Jon Ison
posted on 9/11/12 at 08:15 PM Reply With Quote
You guys obviously to young to remember. Guess it shows my age, that was the only way to get ultimate power from your mini at one time that it appears is longer ago than I thought.
mookaloid
posted on 9/11/12 at 08:17 PM Reply With Quote
I thought mini when I saw that too - definitely an age thing
CRAIGR
Contributor
Posts 2769
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 9/11/12 at 08:20 PM Reply With Quote
Split 45's Aaahh the noise inside the mini was ........loud!!!
steve m
posted on 9/11/12 at 08:31 PM Reply With Quote
all the minis ive owned or driven had four cylinders
unijacko67
posted on 9/11/12 at 08:38 PM Reply With Quote
Brave, also minted back in the day as Twin 40/45 where the thing to have. Night rally regs stated only two chokes, single cam and 4 cylinders. So splitting them meant you could line them up perfectly to two ports each, although I used a single 45 on a swan neck manifold as only the real money chaps bought two and butchered them.
Happy days back in the 80s.
http://www.kittenkitcar.co.uk
Canada EH!
posted on 9/11/12 at 09:12 PM Reply With Quote
One of the reasons I am partially deaf, two Weber throats behind an ali plate over the speedo hole and a 970S turning 7000 rpm and wearing an open face helmet and no ear protection. Oh! the good old days.
posted on 9/11/12 at 09:38 PM Reply With Quote
Eventually Weber brought out a single choke version of the DCOE especially for use as pair on the A series.
posted on 9/11/12 at 09:46 PM Reply With Quote
In the UK Mini racers were left choking on the dust left by 998 Imps before they disappeared off into the distance.
ReMan
posted on 9/11/12 at 09:48 PM Reply With Quote
:-0
http://www.youtube.com/watch?v=977ZRV-X7z8
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
snapper
posted on 10/11/12 at 09:26 AM Reply With Quote
And siamesed inlet ports, that's only 2 for the 4 cylinders
I eat to survive
I drink to forget
russbost
posted on 10/11/12 at 10:17 AM Reply With Quote
Yup, I remember these, had them on our AutoX Mini about 37 years ago!!! 850cc Mini screaming up to around 8,000rpm & as said only thing between you & the trumpets was a bit of thin ali, perhaps thats why I am also slightly deaf!
posted on 10/11/12 at 03:14 PM Reply With Quote
My brother a 45 DCOE (just a single one) on his 1380 mini with a simple alloy box fitted into the bulkhead. He also had straight cut box and straight cut drop gears. We drove it from Plymouth to Silverstone for the Mini 25th Anniversary celebrations, and both of us had ringing ears for days after. Young and foolish...
skydivepaul
posted on 10/11/12 at 04:02 PM Reply With Quote
you also had to cut out the bulkhead in the mini to fit them in
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
Fatgadget
posted on 10/11/12 at 07:36 PM Reply With Quote
Never heard of this one ..What was its desgnation?..And did Brirish Leyland Special Tuning ever use it? I remember they experimented with Lucas mechanical injection albeit on a 8 port head though.
Incidentaly,why wasnt a single 45DCOE just as effective?
[Edited on 10/11/12 by Fatgadget]
posted on 10/11/12 at 09:38 PM Reply With Quote
taking the topic away from Minis, I seem to recall something similar being done for the B series engines (for MGB) but without chopping the carbs - again one choke from each carb feeding the siamesed inlet ports .... or did I dream that up?
picture anyone?
skydivepaul
posted on 11/11/12 at 12:48 AM Reply With Quote
with a 45 dcoe the two chokes are too close togethor. a split 40 dcoe gives you the exact distance to make a straight fuel inlet for both ports
makes a few bhp difference and can seperate the winners from the losers
HD CCTV
IP security systems
posted on 11/11/12 at 08:23 AM Reply With Quote
Had something to do with charge robbing which made the outer cylinders run rich and the inners weak
DIY Si
posted on 11/11/12 at 11:34 AM Reply With Quote
It's not just you old boys that know about split dcoes! Anyone who's read Vizard's A series book should know about them too. Just as with using a 48 IDA for full silliness, like this:
Sun Tzu, The Art of War
iank
posted on 11/11/12 at 11:57 AM Reply With Quote
To be fair Vizards book only has 1 small section I could find regarding split webers (I checked this morning) and reckons they weren't really any advantage in the end.
It's only for getting a straight shot down at the ports apparently.
[Edited on 11/11/12 by iank]
Anonymous
DIY Si
posted on 11/11/12 at 01:21 PM Reply With Quote
Ah, I remembered it being more than that, but my copy's buried in the garage somewhere.
posted on 11/11/12 at 05:07 PM Reply With Quote
But they only had two inlet ports
kipper
posted on 12/11/12 at 10:16 AM Reply With Quote
I remember in the dim and distant passed fitting twin Amal monobloc bike carbs to my mini with one float chamber cut off and being fed from the float chamber of the other carb.
Wish I had a camera in those days
Denis.
Where did that go?
