davidimurray
| posted on 1/5/14 at 06:16 PM |
3d printed turbo
Wow
http://youtu.be/DNedUZxP8NU
Note the comment " we 3d print the internal moving parts inside the housing so the come ready assembled"
Clever stuff!
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
bi22le
| posted on 1/5/14 at 08:12 PM |
Pretty impressive. IT must be ++ expensive, interesting they decided to make it in stainless not titanium!
No maintenance either. Just fit a new turbo each time.
Please read my ring story:
Grimsdale
| posted on 2/5/14 at 10:35 AM |
I'd love to see them doing it. Needs a little more explanation, although i doubt they're that keen on letting competitors know. I'm
sure however that the impeller and bearings wont be made at the same time!
davidimurray
| posted on 2/5/14 at 10:49 AM |
Obviously couldn't do the bearings, but can't see any reason why you couldn't make the impeller inside the housing if using
something like SLS.
mcerd1
| posted on 2/5/14 at 11:57 AM |
quote: Originally posted by davidimurray
but can't see any reason why you couldn't make the impeller inside the housing if using something like SLS.
would SLS make an impeller strong enough to withstand 60000 rpm or more at hundreds of degrees C and not suffer from creep in the process....
to avoid creep on the jet turbines they go as far as casting each blade as a single crystal - I don't know for sure, but I'd think SLS or
similar methods would give you more crystal boundaries than just a bog std. casting...
coyoteboy
| posted on 2/5/14 at 12:03 PM |
SLM (different to SLS) can make 100% dense parts now, should be no problem at all if you can get powder form of the base material. However they will
still need finishing as far as I can tell, as the finish is never great even on the most expensive parts made on a £1m machine.
https://www.youtube.com/watch?v=4odUhDjKHzo#t=291
The extremes a gas turbine blade sees are massive in comparison with a turbo blade, turbos are pretty much agricultural in comparison.
[Edited on 2/5/14 by coyoteboy]
https://www.fixmystreet.com/
Grimsdale
| posted on 2/5/14 at 12:52 PM |
As far as i'm aware, you'd only be able to put down one type of material at one time, and the metal used for the housing would never be
used for the impellor. As mcerd1 says, there are many factors within the microstructure and processing history that confer strength and
corrosion/oxidation resistance than purely the chemical composition of the metal.
[Edited on 2/5/14 by Grimsdale]
coyoteboy
| posted on 2/5/14 at 06:22 PM |
You can lay down different materials in thew same build and you can create functionally gradiented parts where you can go from one alloy at one
location to another alloy (or another entirely different metal) at the two ends of the same part. You just blend the powder feed material and pick
metals that mix when melted.
