Author: Subject: Waxoyl
myke pocock
posted on 16/10/14 at 07:06 PM Reply With Quote
Waxoyl
Been trying to use my new Waxoyl kit today. Put the 2.5 litre can in a bucket with very warm water for about half an hour but it still comes out like thin snot!!! Whats the best way to heat it up? I presume it should come out nice and thin from the end of the flexible probe?
adithorp
posted on 16/10/14 at 07:32 PM Reply With Quote
Have you read this...
Waxoyl tale
http://jpsc.org.uk/forum/
CosKev3
posted on 16/10/14 at 08:02 PM Reply With Quote
Waxoyl is crap
Much better products available from the likes of Bilt Hamber and Dinitrol.
Aerosols are much easier to use
coyoteboy
posted on 16/10/14 at 08:31 PM Reply With Quote
I've not found waxoyl hard to use? Why are the other products better? Just because some people can't handle a compressor or do they actually perform better?
https://www.fixmystreet.com/
mark chandler
I stipuck some into a Shultz gun, nozzle got blocked and the can split spraying me in it, had to wash my hair in petrol
That aside I have always found it pretty good, provided you get in in with enough pressure that you see vapours pouring out the other end of whatever you are filling.
myke pocock
posted on 16/10/14 at 08:36 PM Reply With Quote
Not seen any vapours. Do you always have to thin it with white spirit then? How have you warmed it up then Mark C?
cliftyhanger
posted on 16/10/14 at 08:54 PM Reply With Quote
I sit the can in a large saucepan on a low heat for a while. Over an hour of simmering.....
It can be thinned with some white spirit to help it flow, especially this time of year.
Now, I have been using waxoil for years with success. In areas of high exposure I mix about 10-20% underseal, messy but very good once applied.
However, recently I had to repair a friends car, a chassis leg had an area of rust, very localised. The leg (it turned out) had been filled with waxoil and it had dried and pulled away in the area, trapping some water=rust.
I have also used Dinitrol, I have the very thin one which seems to creep better into existing non-shiny surfaces (ideal in box sections, door bottoms etc) and also a more robust version that is applied over the top. All seems good so far, but the car has not left the garage.....had good reports though.
coyoteboy
posted on 16/10/14 at 10:25 PM Reply With Quote
I heated mine in a bucket of hot water, but it does take replacement of the water with fresh - you're heating a very large quantity of phase-changing material, it takes a lot of energy due to the melting process and large mass.
CosKev3
posted on 16/10/14 at 10:54 PM Reply With Quote
Better in all areas from my experience.
Easier to apply, thinner so gets in all small areas etc, does not crack like waxoyl does if applied too thick, looks better.
Will never use Waxoyl again
coyoteboy
posted on 17/10/14 at 10:38 AM Reply With Quote
Might be worth a shot then, I've never had a problem with waxoyl but I've got a nice 2010 car I'd like to get protected ASAP with winter coming on so this thread is great. Hard to know what the UB, UC and S50 variants are designed for.
Charlie_Zetec
posted on 17/10/14 at 11:00 AM Reply With Quote
I've just Waxoyl'd the inside of my new Defender chassis, and had no problems with it. I did only use a 1L tin on the compressor-driven spray gun though, and all I did was shake vigorously for 10mins before using - already quite liquid and free-flowing (although it was a moderately warm day). I never had any issues with it before, although I have read reviews that suggest stone-chip is better used in wheel arches and areas that are prone to more high impact stones etc..
