Bonnet bumper rubber
coyoteboy - 30/10/23 at 04:09 PM
I have a car that is knocking on 30 years old now and the bonnet hinges are getting a bit of play. They're pressed items and not adjustable, and now while the bonnet is latched I get constant scratchy jiggly rattles as it goes over bumps and the body flexes. It's driving me nuts.
In an effort to diagnose it, I trapped some neoprene under the hinge area to just preload the hinge a little upwards and this silenced the nuisance.
Is anyone aware of a location to buy firm rubber strip that is bond-on, or adjustable height bumpers that I can cut and bond? The neoprene compressed and the rattle returned after a week.
Schrodinger - 30/10/23 at 04:20 PM
How about CBS https://www.carbuilder.com/uk/self-adhesive-strip
Trim strip
nick205 - 30/10/23 at 04:40 PM
You might give Woolies a look
https://www.woolies-trim.co.uk/p-1726-flat-black-rubber-strip
gremlin1234 - 30/10/23 at 09:08 PM
draft excluder tape
https://www.amazon.co.uk/foam-tape/s?k=foam+tape
https://www.amazon.co.uk/DIY-Doctor-Adhesive-Stripping-Excluder/dp/B091HPDSH4
coyoteboy - 31/10/23 at 01:44 PM
Thanks for the suggestions folks, problem is they are all a bit soft, the neoprene I used was an old kneeling pad 10mm thick and that rapidly compressed and stayed compressed.
I see a bunch of screw-in rubber stops but I dont have any screw threaded holes and I'm not planning to drill any but im sure there must be bond on options my Google foo is failing me for.
nick205 - 31/10/23 at 03:19 PM
Any chance of replacing the actual hinges to overcome the wear?
coyoteboy - 31/10/23 at 03:31 PM
Discontinued, online sources are pushing the price up to 75 quid per side 😭
Dingz - 2/11/23 at 08:37 AM
I think you’ll find most foams will take on a set quite quickly, try a solid but low shore solid rubber if you can.
gremlin1234 - 2/11/23 at 08:46 AM
how about stick on rubber feet
https://uk.rs-online.com/web/p/enclosure-accessories/1368967
there is a range, all self adhesive except 136-8970
coyoteboy - 2/11/23 at 08:50 AM
I couldn't find anything the right shape/firmness so I'm going to go with the rubbers off a similar vehicle and cut and bond them.
Surf Bonnet Rubber
Surf Bonnet Rubber
coyoteboy - 2/11/23 at 10:40 AM
do RS still do private customers?
gremlin1234 - 2/11/23 at 12:25 PM
I just checked, yes they do, you can even buy stuff as a guest, without registering
I think for Farnell, you use cpc as a private customer.
ps, I noticed the item I linked to is on back order.
coyoteboy - 2/11/23 at 12:27 PM
Ah nice. I moved to NL a couple of years ago and they won't sell to private folk in europe, but while I'm back in the UK I will order from there. Thanks for the heads up!
