Hi,
I have 1999 Sylva Striker and am wondering whether the new Raw Striker body panels fit without too much work.
Striker classic panels are still available. Should fit fine. The modern striker with new skuttle would require changes to the skuttle and dash area, inc cutting of metal work.
Cool, available from Raw?
Yep should be, just give them a call, i've had plenty of bits from them including body work for my Sylvas
I did it with a 1988 live-axle Striker I rebuilt from scratch. New shape bulge-bonnet and nose fit OK, new style rear tub with removable arches fit
OK. I went for the new scuttle which meant cutting off the triangular old-style metal work. If you do this you need to specify the bonnet that will
fit to the scuttle as there's a difference in length. They supply a new shape bonnet (with the bulge) to fit either configuration.
Cutting off the old-style scuttle means adding metal where the steering wheel mounts. I added additional tubing to stiffen it up. So, to keep it
simple, and if you like the old triangle style, keep it and use new bodywork for that configuration .. It all fits ..
Also, the pedal box suits a Xflow. I went Zetec so had to remove the old style pedal box as the master cylinder interfered with the inlet manifold.
Raw sold me a new pedal box to weld in, which reverses the master cylinder. No problem if you're staying Xflow though ..
Cheers !!
Oh, and as you can see from my avatar image, I added a significant full roll cage and also a bigger tank (almost doubled the fuel capacity) to improve
range ..
Cheers !!
Originally posted by FatChapChipChop
Oh, and as you can see from my avatar image, I added a significant full roll cage and also a bigger tank (almost doubled the fuel capacity) to improve range ..![]()
Cheers !!
I'm back home Friday. Will send pics then. Basically cut away the old pedal box and weld in the new. It sits in the same place and is located by
passing the steering column through it.
I'm back home Friday. Will send pics then. Basically cut away the old pedal box and weld in the new. It sits in the same place and is located by passing the steering column through it.
