Got a trackday coming up and need some more rear pads soon. Did the Raw strikers (factory built) come with sierra rear calipers in general?
Assuming discs?
Golf calipers was standard when I bought (in 2009), with Sierra as option., Not sure what discs when Golf used, I suspect sierra still though.
Golf bolts to upright, sierra uses bracket built into hub carrier.
Golfs identifiable by fins on top of caliper, sierra has noticeable springs for handbrake cable.
[Edited on 27-7-17 by loggyboy]
Ah right, thanks, I had heard of golf hubs being used in another mention
What golf is it do you know and I will order some pads, they are low and would be good to have some backups in case they run out!
Ok, thank you, thats a great help.
