Markymark
| posted on 3/9/17 at 01:21 PM |
Fury Scuttle Panel measurement
Hi All
Is there a kind Fury owner who could measure their front scuttle panel for me please?
I'm looking for the distance from where it attaches to the chassis at the front to where it goes vertical at the back. In line with the steering
column if that makes any difference.
  Fury Scuttle Panel
This section on the above (thanks Rob, nicked from the internet)
Many thanks in advance
Mark
scudderfish
| posted on 3/9/17 at 04:27 PM |
Approx 17cm
https://goo.gl/photos/da3SRTDpfVVVJMpG7
adithorp
| posted on 4/9/17 at 10:59 AM |
175mm on mine.
Mine has the chassis with spurious extra 1" length making getting the bodywork to fit difficult. Newer chassis from BAGH/Steve don't have
that. Even so, I think it'll need a lot of trial fitting before you trim.
http://jpsc.org.uk/forum/
Markymark
| posted on 4/9/17 at 12:53 PM |
Cheers guys
Thanks for that, it's not for trimming as I don't have the body yet!! I just needed an idea of the distance, so where my Alfa 164 steering
column comes through, whether the UJ is on the inside or outside the bulkhead (fully sliding as original is adjustable) so I can make up and fit a
bracket for the lower column support bearing.
  Alfa steering column
I appreciate your help
Mark
