cornish striker
| posted on 6/10/15 at 07:45 AM |
Striker roll bar
Hi I have a Sylva Striker that was built in '91. I've just started competing in sprints and hillclimbs with it.
I seem to remember that the Striker roll bar has been RAC approved for Motorsport can anybody confirm this?
Many thanks Nathan
jeffw
| posted on 6/10/15 at 07:57 AM |
It is unlikely that a '91 Striker rollbar is MSA approved today. You need to refer to K.1.6.1 in the Blue Book and see if you rollbar meets K1
or K2 specification.
loggyboy
| posted on 6/10/15 at 08:26 AM |
Rac 'approval' doesn't exist. The term is applied to a roll bar that meets the standards required in the MSA bluebook (previously
RACMSA)
Mistral Motorsport
cornish striker
| posted on 6/10/15 at 08:53 AM |
Thanks for the replies. It seems that the design meets the diagrams in the blue book. However the diameter of the the tube on the car is 38mm, the
blue book states that it should be 45mm unless the roll bar was approved before 1995 which means 38mm is acceptable.
Thanks Nathan.
loggyboy
| posted on 6/10/15 at 09:02 AM |
I suspect to be accepted you would need an MSA log book signed off by a scrutineer for the car to prove it was used before that date. A call to msa
might br needed.
Also, more importantly, I would want a rollbar to meet the current standards anyway, theres a no doubt a good reason why they want them to larger
sizes!
Mistral Motorsport
jeffw
| posted on 6/10/15 at 09:29 AM |
I assumed this was a road-going car so wouldn't have a log book.
cornish striker
| posted on 6/10/15 at 09:33 AM |
might br needed.
sizes!
Yes I understand what you're saying regarding roll bar diameter but on some events this year I've seen new homologated cages fitted to
Westfields with 38mm bars so it's all a bit confusing. I'm competing in my last event for the year this weekend so I'll have a word
with the scrutineers. I just wanted to try and get any info. I could.
Many Thanks. Nathan
jeffw
| posted on 6/10/15 at 09:42 AM |
There are two systems of approval going on here.
1. ROPS (rollbar or cage) which is built exactly to the Blue Book (K.1.6.1/K.1.6.2) and is therefore allowed
2. ROPS which has been tested/certified/Homologated/Approved by the MSA (hence the 38mm Westfield cage)
unless you can find an approved ROPS from a supplier for your vehicle you are left with option 1
[Edited on 6/10/15 by jeffw]
cornish striker
| posted on 6/10/15 at 09:57 AM |
Ah I see, with regard to option 2 bearing in mind the the roll bar on my Sylva was 'factory supplied' with the chassis, and the history
that the Striker has in motorsport does anybody know if the Sylva roll bar has ever been Approved by the MSA in the past ?
jeffw
| posted on 6/10/15 at 10:09 AM |
As I said....very unlikely. But speak to Jeremy if you want to confirm.
loggyboy
| posted on 6/10/15 at 11:04 AM |
Rops approval is an expensive process, so few do it. Procomp are the only kit manufacturer I know of who do.
Sylva didnt and raw don't have one.
Ones that do have a certificate/approval number fixed to them.
I also believe its only in recent years its been available. I doubt it stretches back to 92.
[Edited on 6-10-15 by loggyboy]
Mistral Motorsport
cfc999
| posted on 21/10/15 at 09:21 AM |
Striker Cage.
Please see the pic of my striker cage if this helps.
