Author: Subject: compomotive cxr's
bigfoot4616
posted on 8/6/15 at 04:27 PM Reply With Quote
compomotive cxr's
i'm in need of a couple of cxr's. 13 x 7 or 13 x 8 in a ford PCD(108mm), the offset needs to be -7. for some reason compomotive can not supply anything less than a 0 offset like they used to do and i didn't really want to run spacers if i can avoid it.
thanks
[Edited on 8/6/15 by bigfoot4616]
bi22le
posted on 8/6/15 at 09:22 PM Reply With Quote
For your striker?
That's a strange set up.
Please read my ring story:
bigfoot4616
posted on 8/6/15 at 10:45 PM Reply With Quote
yes, for the striker. i'm not sure what is normal for a striker but when i got the car it came with 7" wheels at -7 offset.
for the slicks for track use i run 8" on the rear and at -7 there isn't much clearance on the forward facing trailing arm, just under 10mm i think.
as the supply of narrow slicks has dried up i need wider rims for the front to run the wider slicks so tyre to wing stay clearance becomes an issue.
daniel mason
posted on 9/6/15 at 06:14 AM Reply With Quote
Have you had a look on uphillracers rich?
There fairly popular on there as a relatively cheap and relatively light option!
bigfoot4616
posted on 9/6/15 at 08:41 PM Reply With Quote
thanks dan, that's where i was trying to remember what it was called.
