Couple quick questions,
My GSXR600 pump has 2 outlets on it, why is there two? (ones 8mm the others 6mm)
Secondly, just wanted to check where the fuel inlet on the carbs are, heres a pic of mine
Is it the hose you can just see sticking out the bottom of number 2 carb?
Also what is the black thing attached to the T-piece?
Mikkel
if e pumps for a injection system then one will be flow and the other return but you shouldnt have two on a carbed pump unless im missing something
should be from a carbed pump,
Its exactly like this one... theres an 8mm outlet just under the hose you can see in this pic
