Own up!
JoelP - 22/5/04 at 10:58 PM
how many of you finally got the indicators working to find that they flashed the wrong sides, even though much effort might have been spent making sure it was the right way round?!
cant edit the blanks out unfortunately...
[Edited on 22/5/04 by JoelP]
JoelP - 23/5/04 at 08:56 PM
only me then.... thats bad.
liam.mccaffrey - 26/5/04 at 01:27 PM
its not a big problem all you have to do is take the indicators off and swap them over,
JoelP - 26/5/04 at 01:43 PM
i swapped the bulbs over, but nothing changed. so then i swapped the entire unit over, but again, they're the wrong way round still. so i turned the entire car upside down, but the engines too high (low) and hits the ground, plus you twat your face on speed bumps. might just scrap it and start again...
Peteff - 26/5/04 at 01:51 PM
How about putting the steering wheel on the other way round and facing the back of the car. It's obviously a left hand drive flasher unit Joel, swap it for a British one.
JoelP - 26/5/04 at 01:54 PM
that explains the scrapes on the roof of the donor then... he must've had it the wrong way round too.
damndmandamnadmnadmnadmnadmn
