Looking for ideas really.
I'm thinking of getting a catch tank for the breather on the engine. I dont really want to feed it back to the intake, just wondering who's
made their own, and how they did it?
Ive seen drinks cans (or are they just covers?) Or aluminium water bottles
I know they're heavy, but what about disposable welding gas cylinders?
Lets see what you've made
I made one to fit the corner of the engine bay on my x-flow car out of sheet steel and a £5 airfilter
Pre sva 09
Regards Dan.
When I needed one, I used a plastic milk container untill I had time to make one.
You could go the locost method and just use a plastic drinks bottle (500ml size) and drill some holes in the cap for the ventialtion and the breather pipe.
Easy to weld a bit of steel pipe to so a mini cone filter can be added on
Me too, and its still on
cheap light and helps save the planet.
windscreen washer bottle. PU the breather pipes in.....
I wandered down to homebase and picked up a stainless sugar container for a couple of pounds, punched a couple of holes in the lid, inserted some grommets and pushed the engine hose and filter.
How about 1 of these?
http://www.ebay.co.uk/itm/1Ltr-Aluminium-Water-Drink-Sport-Carabina-Bottle-Flask-Cycling-Camping-Hiking-/260954044352?pt=UK_SportingGoods_HikingEquipm
ent_RL&var=560088034983&hash=item3cc212b7c0
After 2 years using an old WD40 can with a hole in the side I got one of these..
Linky Catch Can
( took about a week to wait
http://www.ebay.co.uk/itm/1Ltr-Aluminium-Water-Drink-Sport-Carabina-Bottle-Flask-Cycling-Camping-Hiking-/260954044352?pt=UK_SportingGoods_HikingEquipm ent_RL&var=560088034983&hash=item3cc212b7c0
They weigh next to nothing and you can get a lightweight ally +1
I use two in ali . one for oil , and one of an overflow
there cheap, and don't look to bad
oh, and very light !
steve
Very interesting!
So do they not have to be well sealed? obviously theres a filter on there, but I mean for dirt and stuff getting in through unwelded joints.
Could I just take a bottle and stick a hose in the top with no cap? Or does it need pipes glued on?
Anyone got any pics of theirs?
Might have a go with a disposable gas bottle tonight, just for something to do
Have to add, i bought mine in the local pound shop
can not remember how much they cost though
I got a SIGG 500ml bottle for 99p, screwed in two compression fittings, stuck in two bits of 15mm copper pipe and filled it with pan scrubbers (metal). Ran it back to the turbo inlet, worked fine for 5 years until I decided i couldn't be bothered with it anymore- no reason, just took up space.
Very interesting!
I use a coke can. Hole where the tab was pulled holds the hose nicely. Very light. Replace it whenever I'm drinking a coke in the garage. Fanta or Sprite cans work too! If you want to be posh put some steel wool inside and lead the pipe to below it. This condenses the oil/water vapour so it drops to the base of the can. Cheaper than a mini filter. Possibly more effective too. I have seen mini filters saturated with oil virtualy stopping gas flow.
Plastic bottle or coke can it is then! :-) can probably attach that to the side of the engine with a single bolt and p clip somewhere too.
Is it ok for iva too? Or will he want to see something more professional looking?
Lots of usable ideas for a simple effective can.
Unless of course saddled with a Crossflow in which case a serious and hi capacity Catch can setup is Mandatory.
Those dinosaurs wee out their oil at a prodigious rate.
WD 40 tin as catch tank
I started with this and now have a old spray gun canister with a small filter fitted on top
Jacko
