Wire Locking
omega 24 v6 - 18/10/05 at 09:23 PM
This may sound like a stupid question. When wire locking bolts is it normal to buy them with the hole already in or do you just drill a hole yourself. If you drill it yourself does it affect the tensile strenght of the bolt.
This is just a general question and does nor relate to any specific application.
Alan B - 18/10/05 at 09:36 PM
You can buy them.......or drill i guess...so longs as you don't drill too big,..
derf - 18/10/05 at 10:13 PM
It's alot cheaper to drill yourself, even taking into account the cost of the drill bit.
Rorty - 19/10/05 at 05:52 AM
Some Mil spec fasteners are drilled for wire, but I'm not aware of any UK fasteners that are.
You can buy a natty little aluminium jig for drilling both hex head and socket head fasteners. Most race shops sell them. It's damned fiddly and you'd need to buy a bulk pack of bits.
If you are looking for large quantities of the same size fastener you could speak to a local supplier or even your local laser shop. They can just burn holes straight through the heads/corners.
