A simple question this one.
What are peoples completed car weights, it would be interesting to compare for what engine is fitted etc......
As a starter i have a 2l pinto and sva weight fully fuelled (deducting my own weight) 630Kg
cheers
Mine is a Locost 1800 CVH, Escort Axle, 5 speed, steel floor.
655kgs (inc 6 gals of petrol)
I must have used heavy welding wire!
See the car at: www.groovy42.freeserve.co.uk
I have a MK indy blade (98 w engine)which weighs in at a rather heavy 470 kg when Sva'd, more detail: no reverse, Cosworth LSD with 3.62 ratio
diff (possibly right ratio) discs all round
Jim
[Edited on 17/7/03 by Jim]
Come on everybody this could be a good idea, ( Just read it off your MAC certificate!!!???) you can quote more than the engine and weight
,axle/diff,gearbox, BEC with or without reverse box.
Are there any other resources for engine weights(pinto,cvh,xflow,vauxhall,'k' series,rover v8,ford v6,ford cosworth.massey ferguson
tractor!!!)
[Edited on 16/7/03 by Surrey Dave]
Surrey Dave:
Stuart Taylor Locoblade 97 engine 25 litres of fuel sierraa 3.62 diff 440 kg.
MK indy Vauxhall 2l xe engine, 6 gallons petrol and myself- 580kgs.
Since SVA i've added screen (perspex) and a few other bits n bobs so it could be couple of kgs heavier
I missed this when it first came around and I need to know the weight of a 1300 xflow/5 speed serria box/escort axle/steel chassis and floor and 1 fat
southerner thanks for you time.
Barrie
Still having trouble finding weight of my car anyone passed SVA with a 1300 locost?
[Edited on 21/10/03 by barrie sharp]
how is it that the BECs seem to weigh around 200kgs less when the engine surely isnt THAT much lighter than a car engine?
I would have thought engine and gearbox difference would have been around 80-90 kg. Suspect bke eng cars built with a very close eye on weight.
Oi Rorty, where's the Beemer weights?
Some interesting stuff here
interesting to see the weights of various tyres and wheels - the tyres seem to have the same kind of range as the wheels listed. Admittedly the wheels are all at the lightweight end of the spectrum but I'm kinda surprised the tyres are that heavy.
