carcentric
| posted on 6/4/04 at 04:33 PM |
Locost overdrive
I can't find a narrow rear axle with a 3.1 to 3.3 ratio, so I'm trying to figure out how to "overdrive" the 3.89:1 rear end I
already have. What I've come up with is sketched below - an 11 tooth sprocket driving a 9 tooth sprocket (connected by a chain, of course) for
an overall ratio of 3.18:1.
Is there any better, cheaper, lighter weight way of "overdriving" my differential? Power would be from a 50 hp CX500 engine so I
don't need a lot of strength.
If the sketch doesn't show, it's at http://www.carcentric.com/trikeoverdrive.gif
M D "Doc" Nugent
gjn200
| posted on 6/4/04 at 05:09 PM |
How do you tension the chain?
And I *think* you will be going backwards.
[Edited on 6/4/04 by gjn200]
<- Me!
britishtrident
| posted on 6/4/04 at 06:19 PM |
It would only work with an irs setup on live axle the chain will jump off because the diff moves fore and aft as it goes up and down and steers
slightly in roll.
Much easier just to switch to an irs or de Dion and get a diif from a 2.8 Granada.
If you want stay with a live axle it is quite common to "narrow" Rover V8 SD1 axles to fit MGBs
| posted on 6/4/04 at 06:43 PM |
i've been lookin into this option in my plans to make a twin bike engined middy. My stumpling block was the bearing that holds the ends of the
various propshafts. just couldnt find a supplier of good bearings. The chains and cogs are a piece of pisss to find.
and as already said, it wont be happy with a live axle.
this is for the trike, isnt it?
carcentric
| posted on 6/4/04 at 07:14 PM |
responses
britishtrident - The differential is a swing axle Triumph Spitfire unit bolted securely to the bike/trike subframe (i.e., it would not move relative
to the engine/trans). The Spitfire is the smallest/lightest diff with axles available over here - no, we don't got no Reliants . . .
gjn200 - Tensioning the chain would be done by moving the pillowblock bearing (lime green) for left or right - it has elongated mounting holes for
this purpose - or shimming under the pillowblock for up and down. Also, an idler sprocket tensioner could be added. As to 5-speeds in reverse,
I'm pretty sure I've figured that out - the rule of thumb seems to be if a bike has the shaft drive on the right side of the rear wheel
(viewed from the rear, e.g., a Honda CX500), it turns the same direction as the car's propshaft; if the bike drive is on the left (e.g., a
Yamaha XS1100), it turns the opposite direction.
JoelP - Yes, it's for the CX500 Trike. The pillowblock bearing at the end of the propshaft is a 1" axle bearing designed for "high
powered" racing go karts. I suppose I could bodge a front wheel bearing into something beefier if that would be necessary.
I'm trying to avoid costs and extra weight associated with narrowing a live axle. Of course, if I had a 3.27:1 gearset from a non-OD Triumph
GT6, I'd be set, but they run > US$375.
M D "Doc" Nugent
Mark Allanson
| posted on 6/4/04 at 08:24 PM |
Can't you use an overdrive unit, my old spit had one operated from a slider switch on top of the gear lever
gjn200
| posted on 6/4/04 at 10:05 PM |
I never realised the maggots drive shaft was on the other side, how odd. Not sure on the pillow block bearing though, most bearings that run at that
speed (for any length of time) are normally immersed in oil,not the odd squirt of grease. Berk(e?)ley replicas use them engines so that may be of
some use if you can find out about them.
<- Me!
stephen_gusterson
| posted on 6/4/04 at 10:10 PM |
i have always liked the cx500 - shame its called the plastic maggot!
cheap as chips now....
atb
steve
carcentric
posted on 6/4/04 at 10:18 PM |
Talk about the obvious!
quote: Can't you use an overdrive unit, my old spit had one operated from a slider switch on top of the gear lever
I actually have one installed in a '71 or '72 Spit parts car in the backyard, but I hadn't considered it for the trike due to the
added weight and longer wheelbase required. I'll at least find out what the weight and length are, though, so thanks for the idea.
M D "Doc" Nugent
Mark Allanson
| posted on 6/4/04 at 10:42 PM |
I know they add a little length, but being ally and small I cannot imagine the weight penalty would be much different than a chain and cog assy
| posted on 7/4/04 at 09:28 AM |
I thought of using a similar idea on a trike but the engine had to be mounted over or alongside the diff so the sprockets would line up. Oval engine
mount holes would allow some chain adjustment but it wouldn't be a problem like on a bike as there is less stretch due to the diff being fixed.
An adaptor to fasten the second sprocket to the diff would be simple enough to make.
| posted on 7/4/04 at 01:17 PM |
how well would a diffs input bearings withstand the pull of a chain? cos obviously a chain isnt an even twist, its more a pull from one side. Would
make my life easier, if it could be done without having to add a short prop to hold the cog.
| posted on 7/4/04 at 03:45 PM |
I don't think it would put any different stresses on the bearing to the ones it already endures. It is in a lighter vehicle which will make it
even less stressed setting off and under engine braking.
