dirth
| posted on 15/3/11 at 11:13 AM |
Older cars from Plans,Evolution and F27
Both of the above were from plans both feature originally a Live Axle,while the Evolution was a touch ugly with the split screen it did feature rocker
arm front suspension,as did the Formula 27,only with a different type.
Anyone ever build one of them?
Front suspension ? Any good?
I believe that the Formula 27 went on to become the F27 from YKC,without the plan option
v8kid
| posted on 15/3/11 at 11:19 AM |
How did the F27 front suspension top bearings work? Was it a mini radius arm shaft?
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
MK9R
| posted on 15/3/11 at 11:29 AM |
i bought plan set number 57 when i was 16 (20 years ago), built the chassis up and the suspension, then discovered drinking and ended up selling the
chassis and all parts from a mkII escort estate i had stripped down. The car was eventually finished by someone, but no idea where it is now or if the
suspension design was any good.
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
dirth
| posted on 15/3/11 at 11:49 AM |
No Metro
then discovered drinking and ended up selling the chassis
done that.........lol
skydivepaul
| posted on 15/3/11 at 01:52 PM |
one of the lads at our motor club hillclimbed a F27 with a busa engine.
very quick car, got some good results until he blew the engine
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
dirth
| posted on 27/1/16 at 04:21 PM |
I've got sets of plans for both the cars I should add somewhere
The better chassis IMHO was the Evolution,
The F27 with the Suzuki engine would more than likely from YKC, which more than likely (again) would be different from the original drawings
Good Grief I felt something was familar, then I checked the previous
| posted on 27/1/16 at 05:08 PM |
IIRC the F27 front suspension had question marks over how strong it was (could be wrong).
May we ask what you're trying to do?
I'd suggest the first step is selecting your upright, then mounting to suit it.
| posted on 27/1/16 at 05:15 PM |
^^^^^ lower wishbone was made by welding on a nut instead of the sronger methid of using a threaded tube.
