ian996
| posted on 2/7/16 at 09:10 AM |
Vehicle Security - Nurburgring trip
We are off to the Nurburgring for a few days in July - just wondering what security people might recommend?
Handbrake lock?
Wheel lock?
pedal lock?
I can remove my steering wheel and remove the ECU. I also have some engine bay locks to fit before I leave. Could also get a tracker fitted, so i
guess someone driving it isn't the issue, but want to make sure it cant be wheeled away on a flatbed. Though i guess someone could drag it on
still - just hoping no-one wants it that badly!
I know a few cars have been stolen from the Nurburgring area so want to make mine fairly difficult.
I don't have a hood or anything, so its all open top. Will be packing waterproofs - plenty people in the convoy with boot space! Plan to just
put a cover over it when not being used.
Simpler the better. i see the wheel locks on ebay are quite cheap, but are probably easily removed. Maybe a strong chain would be better through the
wheel?
I
907
| posted on 2/7/16 at 09:31 AM |
I go for a covered chain & padlock like the motor bikers use, through the wheel and wishbone.
If you use a cover let the chain dangle out from underneath as a visible deterrent.
Paul G
[Edited on 2/7/16 by 907]
Dick
| posted on 2/7/16 at 10:00 AM |
I go for a covered chain & padlock like the motor bikers use as said above through the wishbone and wheel but I chain it to something like another
car or a post, that way they cant drag it away. I brought the best I could find not a cheap ebay item as have seen some of these tested, think my was
Thatcham approved to
jeffw
| posted on 2/7/16 at 10:18 AM |
Pick a hotel which has garages for rent is what we always did.
ian996
| posted on 2/7/16 at 10:29 AM |
will have a look at the chains. anyone know if it will fit through a TD1.2?
bi22le
| posted on 2/7/16 at 01:26 PM |
I have not heard of cars going missing at the circuit. You would be lucky to get a flat bed into the carpark and steal a car in any decent time. Maybe
the gravel one at the end but I used to always find space in the main one as I was in out with people so often.
There is also far more expensive and exposed cars there. Millions of pounds of cars just parked at the sides of the roads and satellite car parks.
If you do park in the gravel car park, parking close to some one and tying a cars together is a good idea, make sure you have locking wheel nuts
though!!
I have always stayed at the same hotel that is about 30 mins away, it has a secluded car park, garages to use and CCTV.
Please read my ring story:
ian996
| posted on 2/7/16 at 06:11 PM |
It's not at the facility I'm worried about, it's when I'm asleep in the hotel. I guess motorbikes have the same problem and i
know a Westfield isn't the most desirable of cars, it's just, in my view, easier than most to take!
jossey
| posted on 2/7/16 at 06:17 PM |
I chain the rear wheels and out the car on full lock if you have a ignition steering lock.
Also as you say remove the wheel
I would also put a red led on dash
David Johnson
