grazzledazzle
| posted on 11/9/08 at 03:30 PM |
gasket paper / gasket paste advice
if i make paper gaskets for idle air control valve and tb to inlet manifold, what thickness of paper do i need and should i use any gasket paste?
Mr Whippy
| posted on 11/9/08 at 03:51 PM |
I use to use heavy construction card aquired from work for sealing carbs on cars and makng loads of gaskets, I'd rub in grease to protect it
from getting damp from fuel and sticking. worked perfectly. if the surface is well machined and doesn't rock against each other then thin card
would do.
clairetoo
| posted on 12/9/08 at 05:52 PM |
I just buy proper gasket paper from my local motor factors - they have it in various thickness's
Its cuz I is blond , innit
Claire xx
Will weld for food......
