New Topic New Reply
Author: Subject: SVA info
posted on 10/1/03 at 02:02 PM Reply With Quote
SVA info
If you haven't seen this site before, it is worth a look.
SVA info
There's a lot of relevant info there, even if they're Westfield agents!
cheers,
Findlay234
posted on 10/1/03 at 03:39 PM Reply With Quote
also try::
sva chapters
Jim
posted on 10/1/03 at 10:21 PM Reply With Quote
This site gives lots of references to tapping foam padding on bits. This is now a fail during the test as I found out
Jim
Findlay234
posted on 12/1/03 at 08:08 PM Reply With Quote
what do you have to do now to pass then??? nut covers? what else
cheers
fin
Jim
posted on 12/1/03 at 08:21 PM Reply With Quote
The new regs say it has to look like it is a permanet fixture on the car.
To pass my car I used nut covers, to cover the headlight mounts etc I cut convuluted water tube in half and wrapped it around a cable tied it. To cover the track rod ends etc I just extended the steering rack gaiter. Cable tied again. I removed it after test.
To cover the radius of the front wheel arches I used some self adhesive door protector
Jim
chrisg
posted on 12/1/03 at 10:27 PM Reply With Quote
Apparently split heater hose fixed with tie-wraps (over the track rod)has passed too.
SVA guide on my site too
Chris
Note to all: I really don't know when to leave well alone. I tried to get clever with the mods, then when they gave me a lifeline to see the error of my ways, I tried to incite more trouble via u2u. So now I'm banned, never to return again. They should have done it years ago!
New Topic New Reply
