LBMEFM
| posted on 28/3/09 at 05:30 AM |
Steering pulling
I have a Peugeot Boxer van with power steering. If I make a sharp turn to the left when I straighten up it continues to pull heavily to the left, the
same if I turn sharp right, it pulls to the right. After a few miles its OK. Any suggestions to what's causing this?
ReMan
| posted on 28/3/09 at 08:46 AM |
Rack would seem the obvious choice if there ae no other symptoms (noisy pump, lost fluid,frothy fluid)
Tell me it's electric?
| posted on 28/3/09 at 09:29 AM |
Had a similar problem with a Mondeo a few years ago that I managed to sort out by flushing the system . Disconnect the return to the reservoir and
plug reservoir , place end of hose into a bowl and pour in a 50/50 mixture of fluid and parafin keep filling and run engine until fluid coming from
return hose is clean then flush with fresh fluid. Cheaper than a new rack/box etc if it doesn't work it only costs a few quid.
