JohnN
| posted on 21/2/04 at 12:30 AM |
Thin discs in an angle grinder
Just got to report how fantastic ultra-thin cutting discs are in a 115mm angle grinder.
1.2mm thick, they go through box section and sheet stainless like a hot knife through butter. They are insurpassed for trimming.
A genuine contender for the title "The Tool"
John
| posted on 21/2/04 at 11:11 AM |
i tried using a thin disc in mine but i couldnt tighten it up enough to stop it spinning! do is need a spacer? normal ones are a lot fatter.
| posted on 21/2/04 at 11:36 AM |
Spacers
Yes you do need a spacer! the thread is normally long enough to allow very thin disc's.
Whatever you do - always where eye protection when using these wheels they are very susceptable to splitting. I know they flex, but I saw one bust as
an apprentice and I'll never forget it! If a fragment comes for your eye - your eyelid won't stand a chance of stopping it!
Jasper
| posted on 21/2/04 at 12:09 PM |
Great tool - I love it - use it for trimming all sorts of things!
Brooky
| posted on 21/2/04 at 12:25 PM |
code: use it for trimming all sorts of things!
Like toe nail's !
[Edited on 21/2/04 by Brooky]
Jon Ison
| posted on 21/2/04 at 04:05 PM |
prefare the 0.8mm thick ones............
Staple balls
| posted on 21/2/04 at 04:17 PM |
quote: Originally posted by Brooky
Like toe nail's !
pah, can't beat a dremel for nails/minor surgery
heyzee
| posted on 21/2/04 at 06:07 PM |
cutting wheel
to put your cutting wheel on your grinder without it spinning turn the locking nut the other way round and tighten with the spanner
kingr
| posted on 21/2/04 at 07:11 PM |
I was demontrated the merits of one particular brand of slitting disc (can't remeber which brand sadly) by it having a large triangle chopped
out of the side of it and then being used to chop up a piece of 5mm steel, very impressive.
Kingr
stephen_gusterson
| posted on 21/2/04 at 11:41 PM |
your eye would be history before you ever thought of blinking!
Personally Id be very wary of a thin disk. its easy to stress a disk when cutting, and a thin one had gotta be more fragile.
whats wrong with the normal 3mm type? they have a defined cutting line - A jigsaw or nibbler would remove at least 3mm of material anyway
atb
steve
[Edited on 21/2/04 by stephen_gusterson]
kingr
| posted on 22/2/04 at 12:27 AM |
Ummmm, they take an eternity and they're less accurate?
Kingr
Simon
| posted on 22/2/04 at 01:12 AM |
Gotta agree with the positive sentiments re thin blades.
Less waste material, and therefore dust!
Accurate cuts.
Just don't do what I did - try cutting an engine mounting with the engine unsupported (thought it was!!) - blade just exploded. Glad I was in
safety conceous mode (with googles!)
Simon
blueshift
| posted on 22/2/04 at 01:40 AM |
and less stress on your bearings and motor, grinder lasts longer, everybody's appyyyyy
you know it makes sense.
James
| posted on 23/2/04 at 02:58 PM |
Thin ones are brilliant- is all I use now. Just can't see point of wider ones at all.
I use a 6mm for grinding and the 1.2mm for cutting- perfect combination.
James
Jasper
| posted on 23/2/04 at 03:27 PM |
I didn't discover these until I'd finished cutting all the steel for my chassis, with the wide disks - buggered one grinder and p*ssed off
my neighbours!
stephen_gusterson
| posted on 23/2/04 at 08:55 PM |
there seems no lack of speed on my 230mm grinder with a 3mm disk in it.
cut my outer door panels from stainless 3mm sheet with it on Saturday, no probs.
I need a new stock of disks, so I have bought 5 115mm jobbies to try from screwfix.
atb
steve
[Edited on 23/2/04 by stephen_gusterson]
| posted on 23/2/04 at 10:57 PM |
i just got my thin discs working today, shockingly easy! just glides thru stuff, so much better for the poor old dear next door! Its persuaded me to
keep on with the trailer project that i had abandoned due to noise considerations!
| posted on 24/2/04 at 12:09 AM |
That's why we wear goggles.
I've been using some 115mm 0.8 blades for cutting sheet steel and they are brilliant. They don't snag as much as the thicker ones. As
quoted earlier, turn the securing nut over and they clamp tight. They are not suitable for 230mm grinders but do have the same centre hole size. The
larger gearbox gets in the way and you don't have the same fine control. For grinding welds down get some 40 grit flapwheels or emery disks on a
backing pad, not as vicious as grinding wheels and a nicer finish.
Terrapin_racing
| posted on 24/2/04 at 12:51 PM |
Brilliant if you use one of these from Screwfix and a 0.8mm blade - who needs a hacksaw!
Terrapin_racing
| posted on 24/2/04 at 12:52 PM |
£12 before anyone asks!
| posted on 24/2/04 at 02:24 PM |
that looks like it does compound angles as well! can it? i spent £200 at MM on a band saw, which admittedly is nice and quiet compared to a grinder,
but for the 180 quid difference the neighbours can go to hell with ringing ears!!
blueshift
| posted on 24/2/04 at 02:29 PM |
Yeah, we have one of those chopsaw adapters. May I just say though that the clamp on it is SHITE, plus due to the way it's set up you
can't cut any angle greater than about 30 degrees on it or the blade can't reach the base of the tube.
Still, worth having.
Terrapin_racing
| posted on 24/2/04 at 03:24 PM |
Yep, clamp could do with improvement! - but well "cheap as chips" and always being used
Terrapin_racing
| posted on 24/2/04 at 03:25 PM |
Bet we could make a better one - just can't be bothered at the moment.
Nice little project - could make it do all the mitre angles etc.
Simon
| posted on 26/2/04 at 01:34 AM |
" i spent £200 at MM on a band saw, which admittedly is nice and quiet compared to a grinder, but for the 180 quid difference the neighbours....
I cut all my chassis tubes with a hacksaw (yeah - one blade, and that wasn't even new), so saved even more!!
Simon
