piddy
| posted on 20/5/09 at 06:17 PM |
Fuel sender seals
Hello All. I've been having a few problems with my fuel gauge reading of late, so decided to take the sender out and check it over.
While trying to replace it I found that the sealing rubber washer has changed size so the holes that the screws go through no longer match up.
Presumably this has been caused by its contact with petrol.
Is there a way to get these to revert back to there original size?
Can you buy replacement ones easy enough?
I could easily make a replacement but how do you know what type of rubber to buy?
I found some rubber the correct thickness, how can I test it’s resilient to petrol?
I’ve put a bit in a container of petrol how long should I leave it in there?
Thanks for your thoughts.
| posted on 20/5/09 at 06:25 PM |
You could make one out of cork.
flak monkey
| posted on 20/5/09 at 06:43 PM |
You need a piece of nitrile rubber sheet
I might have a piece at work, I'll have a look when I get a chance.
Sera
http://www.motosera.com
chris_smith
what ^^^ben says mine is also cork
hth
chris
tomblyth
| posted on 20/5/09 at 07:20 PM |
drop it in boiling water ! sometime the seal will revert to is original shape!
piddy
| posted on 20/5/09 at 08:00 PM |
Thanks chaps, I'll see what I can do/ Find to do the job.
