New Topic New Reply
Author: Subject: Cleaning rusty brake discs
Miks15
posted on 13/7/09 at 09:29 AM Reply With Quote
How do i go about cleaning the rust of my brake discs? Theyve been lying around for over a eyar now and have a bit of rust built up on them, i wanna put them on but wana clean them upa nd also paint the center bit of them.
Mikkel
balidey
posted on 13/7/09 at 09:31 AM Reply With Quote
I attack the worst of the crust with a wire brush, then emery cloth, then wipe with brake cleaner. Then emery again, then brake cleaner again.
posted on 13/7/09 at 09:35 AM Reply With Quote
What you need is a slightly abrasive pad that will come into contact with the disc
How bad is the rusting? Is it really bad enough to warrant any form of skimming? Unless there's flaking or pitting I'd just let the brake pads do that for you....
Mr Whippy
posted on 13/7/09 at 09:37 AM Reply With Quote
Electrolysis would be very good for this
posted on 13/7/09 at 09:44 AM Reply With Quote
80 grade production paper in an orbital sader is all that is required --- you want a slightly rough surface not a mirror finiish.
Those paint stripper pads for the end of an electric drill also work pretty well.
blakep82
posted on 13/7/09 at 11:05 AM Reply With Quote
paint the bits you want painted, and let the brake pads do the rest
[Edited on 13/7/09 by blakep82]
________________________
Steve G
posted on 13/7/09 at 11:07 AM Reply With Quote
Depends on what the disks are off - i generally find they are so cheap to buy that i just get a brand new set. Last ones i bought were under £20 per pair!!
James
posted on 13/7/09 at 11:35 AM Reply With Quote
I wouldn't paint either the hub or wheel face.
I found that variation in thickness of paint was enough to cause the disc to 'wobble' such that it could be heard hitting the pads.
After scraping all the paint the problem was gone.
James
posted on 13/7/09 at 01:05 PM Reply With Quote
I've used a flap wheel in an electric drill with the disk mounted on the hub. Hold the flap wheel at an angle and it spins the disc around as it sands the rust off. Doesn't work on driven wheels, have to start the engine and put it in gear for those
iank
posted on 13/7/09 at 06:03 PM Reply With Quote
Brake discs are risky to use electrolysis on due to a small chance of them suffering hydrogen embrittlement - which could theoretically cause them to shatter in use
http://en.wikipedia.org/wiki/Hydrogen_embrittlement
Anonymous
flak monkey
posted on 13/7/09 at 07:36 PM Reply With Quote
THE TOOL!!! (angle grinder with wire brush cup!)
Sera
http://www.motosera.com
DavidW
posted on 13/7/09 at 09:28 PM Reply With Quote
Definitely.
Ninehigh
posted on 14/7/09 at 01:13 AM Reply With Quote
My discs get a layer of rust from washing the car, by the time I get to work it's gone. I know your rust is much worse but be gentle for a while and it'll disappear soon enough
New Topic New Reply
