corrado vr6
| posted on 31/8/09 at 07:26 PM |
Smiths gauge
Evening, I have a Smiths water temperature gauge with the sender attached to the gauge by some insulated cable. I need to buy a hose insert for the
sender to screw into but i dont know what type of thread is on the sender as the hose inserts come in 5/8 unf and 1/8 npt. I have emailed Eurospares
where i got the gauge from but thought i might get a quicker answer on here.
Also rather than start another topic when i do get the hose insert sorted it says in the instructions the sender should always be submerged in
coolant. I have a 06 R1 engine where would be best to place the sender in the top or bottom hose??
Any help is much appriciated Greg
http://r1indy7.wordpress.com/
| posted on 31/8/09 at 07:34 PM |
As far as the thread in concerned measure the diameter and invest in a set of thread gauges and a Zues chart . Will last a lifetime and you will never
need to guess a thread again
austin man
| posted on 31/8/09 at 07:37 PM |
have you also got the voltage regulator? If it the same as the mini item a regulator is needed to drop the voltage
