FrankP
| posted on 9/1/10 at 02:06 PM |
Running for the 1st time in the snow
Well I made some progress over xmas and now have the car started.
As is tradition here is some video of it running
Link
http://www.youtube.com/watch?v=FoBE_f07ZRk
does it sound right/
Frank
zilspeed
| posted on 9/1/10 at 02:13 PM |
Standard injection, well done
| posted on 9/1/10 at 02:15 PM |
Does it have multiple carbs? If so, I think that they may need balancing - it's got a sort of 'lumpy' sound.
Looks like a nice job though!
EDIT: If on injection, also may need balancing?
Either that, or it's just a very slow tickover!
[Edited on 9/1/10 by David Jenkins]
Dangle_kt
| posted on 9/1/10 at 02:21 PM |
is it firing on all four cylinders?
It might be firing on three - hense the odd idle sound.
Touch the manifold (not with your bare hand!) and if any are not as hot you might have a dodgy plug, poor connection or lead.
austin man
| posted on 9/1/10 at 02:37 PM |
are you planning to retain the standard injection Inlet ?? they are a bit cumbersomer I do know where there may be a s econd handGriffin inlet for
sale, which is a lot smaller and fits under the bonnet.
FrankP
| posted on 9/1/10 at 02:47 PM |
Yes I though it sounded a bit rough..
I have checked the ht leads and they are all pulsing and I have new plugs.
Should I check the injectors?
Frank
[Edited on 9/1/10 by FrankP]
MakeEverything
| posted on 9/1/10 at 02:49 PM |
Sounds like youve got a definite "Knock".
Hopefully nothing terminal, but the noise is from the engine and the exhaust note sounds fairly regular. Maybe a big end?
What was the mileage on the engine?
[Edited on 9/1/10 by MakeEverything]
Kindest Regards,
Richard.
austin man
| posted on 9/1/10 at 02:52 PM |
are you using the standard ECU? does the car rev ok, could be a sticking valve or a slight timing problem
| posted on 9/1/10 at 02:53 PM |
That's why I mentioned balancing - my x-flow sounded like that until I balanced the carbs.
MakeEverything
| posted on 9/1/10 at 02:56 PM |
Its injection on a single TB though....?
Kindest Regards,
Richard.
FrankP
| posted on 9/1/10 at 03:12 PM |
I will pull the plugs to see if they are all the same colour.
Frank
big_wasa
| posted on 9/1/10 at 04:40 PM |
Mine with no exhaust.
Are you not running the Maf ?
Have you got any air leaks ? vacume connections that you havnt blocked ?
FrankP
| posted on 9/1/10 at 05:10 PM |
No I am uisng the MAP rather than the MAF.
big_wasa
| posted on 9/1/10 at 05:42 PM |
Ahh ms and not the ford eec-iv or v.
Any reason for not using the ford ecu ?
RK
| posted on 9/1/10 at 05:43 PM |
Wasa, I like your overflow bottle. Where did you find it? Mine looks kind of old and yellowy and want one that looks a bit nicer.
At least your engines run! Minus 15 here and mine won't start.
big_wasa
| posted on 9/1/10 at 06:04 PM |
Mid 90's K series Rover Metro. zr, 25, 200 and others.
Nice neat and easy to mount and I pay about a fiver each.
Not much warmer over here. In the snow and dark at -7 last night working on the tintop.
[Edited on 9/1/10 by big_wasa]
mangogrooveworkshop
| posted on 9/1/10 at 06:23 PM |
Have you put the right oil in the zetec !!!
wrong oil makes it miss like mad...
MakeEverything
| posted on 9/1/10 at 06:45 PM |
Wasa, love your engine cradle, for the testing. Does it twitch or turn at all when you start or rev?
Kindest Regards,
Richard.
adrianreeve
| posted on 9/1/10 at 06:54 PM |
Is that a GBS exhaust? Any good?
Adrian
Don't worry about me - I know three-fifths of sod all about injection systems!
big_wasa
| posted on 9/1/10 at 08:55 PM |
No was all good. I ran it for hours on the trolley.
| posted on 9/1/10 at 09:08 PM |
Check the vacuum hoses as they can split causing rough running/misfires
