cd.thomson
| posted on 1/2/10 at 12:30 PM |
just wrote a list..
of jobs left to do before IVA prep...
fair play a lot of them are fiddly and some bigger than others
BUT
its only 1 page of A4
Craig
Richard Quinn
| posted on 1/2/10 at 12:31 PM |
Yeah, but how small is your writing??
blakep82
| posted on 1/2/10 at 12:33 PM |
and how much detail did you go into? lol
________________________
cd.thomson
| posted on 1/2/10 at 12:34 PM |
haha!
well its bullet points with 12pt Times New Roman, about 50 tasks in total - but that does include little stuff like "buy front lights"
"buy rear lights" "fit reverse light switch"
Craig
spdpug98
| posted on 1/2/10 at 12:37 PM |
Always good to have a list to work from, I produced a spreadsheet before starting my build and worked to that. I also had this on my wall in the
garage which I would put weekly tasks on then turned it into a 'to finish' board (Sad I know!!)
My Blog: http://spdpug98.wordpress.com/
cd.thomson
| posted on 1/2/10 at 12:40 PM |
• Calibrate rev counter
• Fit indicators into scuttle
• Fit wing mirrors into scuttle
• Insulate all connections under scuttle and in engine bay
• Mount brake m/c reservoir
• Mount battery
• Mount coilpack
• Mount EDIS module
• Fit reverse light switch
• Fit handbrake warning switch
• Check speedo cable rotations
• Fit new electronic speedo sender
• Drill and fit gromit to bulkhead
• Route rear loom through bulkhead and into tunnel
• Wire in reverse switch
• Extend brake light switch wiring and fit
• Fit rear wiring into tunnel
• Route temp/oil senders through gromit into car
• Prepare fitment and route choke cable
• Finish dashboard
o Prepare holes for choke, rear fog button, bright-6
o Cover with foam and vinyl
• Finish routing and securing loom under scuttle
• Prepare tunnel for harness fitting i.e. cut away GRP covering bolt inside bolt holes
• Tighten gearlever bolts
• Fit tunnel
• Fit dashboard, wire up all gauges, button and warning lights
• Fit steering wheel cowling
• Inflate tyres
• Calculate RR of wheel (distance covered per one rotation) and program speedo
• Fit harnesses
• Fit seats
• Fit handbrake and gearlever gaiters (and knob)
• Fit accelerator cable
• Bleed brakes
• Wire in low brake fluid switch
• Prepare bonnet
• Fit nosecone in relation to bonnet
• Fit bonnet using aerocatches
• Fit front cycle wings
• Fit rear wings
• Buy horn
• Wire and fit horn
• Buy front lights and bonnet scoop
• Fit front lights and indicators
• Wire in front lights/indicators
• Route front loom
• Fit scoop
• Wire in fuel sender
• Buy fuel filler
• Fit fuel filler
• Buy rear lights (stop, tail, indicator, fog, reverse and registration plate)
• Fit rear lights
• Wire in rear lights
• Route rear loom
• Fit boot tub
• PREPARE FOR IVA
Craig
tilly819
| posted on 1/2/10 at 12:48 PM |
quote: Originally posted by cd.thomson
• PREPARE FOR IVA
my prepare for IVA test list is that long lol
tilly
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
cd.thomson
| posted on 1/2/10 at 12:51 PM |
i did say "before IVA prep"
something im not looking forward to but at least ill be able to drive the car up and down my (single car length) driveway
Craig
blakep82
| posted on 1/2/10 at 01:07 PM |
hmm, i don't even want to start a list
i've sort of done a list of jobs, but its not as detailed as yours!
here's what i've got
http://locostbuilders.co.uk/upload/jobs.JPG
cd.thomson
| posted on 1/2/10 at 01:10 PM |
the reason its so detailed is so it feels that im progressing everytime I go in the garage, rather than it taking a week to cross one thing off..
oh dear god... don't break out the project management software! its enough to bring a grown man to tears!
Craig
blakep82
| posted on 1/2/10 at 01:13 PM |
lol it was my dads idea. its a good one too. as you can see, i'm not using all the time line nonsense on it, or the car should have been done in
2005 lol
RAYLEE29
| posted on 1/2/10 at 01:25 PM |
Good idea perhaps i should do one as i seem to go from one bit to another in no particular order.
its always a case of oh i cant fit that till ive done this oh cant do that till ive made that etc etc
any way at least you know what you need to do
Ray
blakep82
| posted on 1/2/10 at 01:28 PM |
Ray
yep if you can get microsoft project, you set up the order that things have to be done in too. so it helps you know what you can do and when.
it still gets confusing right enough...
RAYLEE29
| posted on 1/2/10 at 03:00 PM |
just had a look at ms project I could get my shocks for that sort of money lol is there a free similar bit of software any where?
sorry for the hijack or should i start a new thread?
Ray
cd.thomson
| posted on 1/2/10 at 03:04 PM |
hijack is absolutely fine
http://openproj.org/openproj
i do stuff like this in my job and id never ever ever apply it to a hobby. i find them soul destroying!
[Edited on 1/2/10 by cd.thomson]
Craig
Bluemoon
| posted on 1/2/10 at 03:14 PM |
Been using that at work to, not bad prog (for free). Never use it on the car, but it is kinda useful, talking of which I need to update a project now
Kinda depressing..
blakep82
| posted on 1/2/10 at 03:19 PM |
i, er, 'borrowed' my copy from work lol
RAYLEE29
| posted on 1/2/10 at 03:29 PM |
Thanks looks interesting will give it a go
  cheers
Ray
Vindi_andy
| posted on 1/2/10 at 03:50 PM |
God im glad this thread didnt appear last year when we were going for SVA else the Mrs would have been using that.
Come to think of it I hope she never finds this thread cos she'll use that for everylittle job
Richard Quinn
| posted on 1/2/10 at 04:51 PM |
Looks as though you were busy on the 17th of August!
blakep82
| posted on 1/2/10 at 05:01 PM |
ha ha, notice only 3 things off that lst have been done
skinned knuckles
| posted on 1/2/10 at 06:39 PM |
your well ahead of me. my list starts with finish welding suspension brackets to chassis
starting to feel good about it again now though. can start to see it in my head as a finished car. I've even picked my colour
A man isn't complete until he's married, then he's finished
blakep82
| posted on 1/2/10 at 07:53 PM |
i've been thinking about colours too! lol
can't decide if painting flames up the front is a bad idea or not
