Krismc
| posted on 11/3/10 at 06:12 PM |
ENGINE RPM/BHP??
Just filling in my paper work to send to MNR for the IVa and unsure of What too put on the iva sheet for max RPM / Revs?
My engine is a 2.0 litre zetec 1999 130BHP standard.
But has lightened flywheel, TBs, Cams, and around 180-190Bhp?
What do i put?? cheers in advance
zilspeed
| posted on 11/3/10 at 06:21 PM |
Play dumb.
6,500rpm.
Doubt if it's hugely over that anyway.
SPYDER
| posted on 11/3/10 at 06:22 PM |
Play dumb.
160 bhp.
Geoff.
| posted on 11/3/10 at 07:09 PM |
For a 16v 6.5k is about right (though sounds scarily high but then I've been DERVing it recently). It depends a lot on the cam, inlet manifold
length etc. I'd stick with stock RPM levels personally to be well on the safe side.
Krismc
| posted on 11/3/10 at 09:01 PM |
Sorry but im sure it means max power and at what RPM i think?
so what revs at peak power, a zetec will rev too 5.5k-5.6k easily? and do i say the max standard power of 130BHp or should i say around 160bhp?
bigrich
| posted on 11/3/10 at 10:27 PM |
as above, play it safe and use stock rpm limits. this is used to set the level for the noise test. so 6500rpm max. noise test at 75% of that. so it
pays to set it at the lowest level you can. Bear in mind the testers arnt stupid and will reject an abnormally low rpm level.
Krismc
| posted on 13/3/10 at 03:18 PM |
so i should say 130bhp and 6500rpm
Ninehigh
| posted on 14/3/10 at 01:21 AM |
What's this paperwork for? I wouldn't have a clue what the power output is on my car... I'd have to fill it in with "not
enough"
Krismc
| posted on 14/3/10 at 08:52 PM |
vosa or dvla not sure, mnr rang me asking? for my iva
