dave
| posted on 20/6/10 at 09:32 PM |
I want it to look like this
Is it possible to get the nice almost flat bonnet line in this car from a locost chassis. Needless to say this is a Caterham and i like it a lot but
cant afford to buy one
austin man
| posted on 20/6/10 at 09:36 PM |
I think the main difference is the nosecone I bought one from Robin Hood which had a similar line but it also has a circle embossed into it so not so
good. Try and get a replica Caterham Nose and work from that
big_wasa
| posted on 20/6/10 at 09:38 PM |
Better still look on ebay for used and damaged body work.
austin man
| posted on 20/6/10 at 09:40 PM |
isnt the catering van slightly narrower than most
daniel mason
| posted on 20/6/10 at 09:43 PM |
you may also need a shorter motor to get under a bonnet as slim as that, otherwise a huge scoop will be needed!
dave
| posted on 20/6/10 at 09:52 PM |
Im using the mx5 engine and gearbox which isnt very tall anyway.
mangogrooveworkshop
| posted on 20/6/10 at 10:42 PM |
i will make the bonnet and scuttle for you if you get a mk nose cone and some ali
Sorry i wasnt in the night.
andrew-theasby
| posted on 20/6/10 at 11:26 PM |
Looks like there someone copying caterham noses on ebay if youve got £150
link
RK
| posted on 20/6/10 at 11:38 PM |
yes buy that before they get their ad pulled. I am sure you can get them for less if you are patient and look around. Did you ask around at Newark?
Someone is bound to have a spare.
Also, making a bonnet isn't that hard. I have a very flat top like you want, by starting with a flat, ally scuttle. The guy sells them on
fleabay once in a while. I have forgotten how to get him, but his name was Martin.
