sdh2903
| posted on 9/8/10 at 04:25 PM |
Locost trailer project
Having accepted the fact that i'm gonna need a trailer for my car at some point I've been keeping an eye out for one.
Found this beut on ebay only 40 miles away. Anyway after a quick haggle it ended up back on my drive! was a bit of a bargain too!
Just need some lights fitting some steadys and some small ramps and a good tidy up. Come with braked indespension units, new 13" tyres and a
heavy duty indespension hitch, rated at a ton too.
One question, the floor is decked out in steel treadplate, which is massively strong but very heavy, just wondered if it was worth putting in a couple
of additional cross members and decking out in ally tread plate?
  trail 1
cliftyhanger
| posted on 9/8/10 at 04:30 PM |
don't wish to worry you, but it looks (in the photo's at least) like the back half if drooping a bit. May be worth a look, and a bit of
re-inforcing if that is the case.
As to decking in ally, guess it would save a bit of weight, but hardly locost. Cheaper would be to lose the decking in the middle, especially if you
can get the edges bent up an inch or two to give more rigidity....
sdh2903
| posted on 9/8/10 at 04:58 PM |
Had noticed that about the droop in the photos, its definitly a lot less pronounced with the naked eye. I'm gonna beef up the back end anyhow
when i sort out some ramps.
I want to try and keep a full deck so I can use it as a gen purpose trailer as well.
I would like the ally plate but as you say its probably take 3 sheets to deck it out and therefore not cheap!
will121
| posted on 9/8/10 at 05:48 PM |
changing the deck to ali would save quite a bit, but punched ali sheet from
here would cost about £200 but would need some extra
support adding some weight
[Edited on 9/8/10 by will121]
SteveWalker
| posted on 9/8/10 at 07:14 PM |
A couple of pieces of box section welded on each side and the ends as sockets, and you'd be ready for a set of drop in sides. Spring clips
through to keep them in place and you'd be set.
[Edited on 9/8/10 by SteveWalker]
Daddylonglegs
| posted on 10/8/10 at 05:19 AM |
Just cut the centre section out leaving enough for the car width then you can drop it back in place to use it as a normal flatbed trailer. Then as
said, add bracketting for the sides.
Simples (well relatively )
sdh2903
| posted on 10/8/10 at 02:00 PM |
Mmm that treadplate is at least 3mm thick mild steel, could be fun trying to cut a section out of it!! Unless someone is kind enough to lend me a
plasma cutter
adithorp
| posted on 10/8/10 at 03:08 PM |
plasma cutter
Rent one.
http://jpsc.org.uk/forum/
