Cadburys Man
| posted on 10/10/13 at 09:37 PM |
Poly Bushes
Would these poly bushes fit my Stuart Taylor Locosaki??
Haynes Roadster Locost Front &' Rear Wishbone Bushes in Polyurethane - Sale
Daz.
Stuart Taylor ZX9-R Locosaki
Bare
| posted on 11/10/13 at 02:59 AM |
Might jusat.. But you do realise that Poly bushes bear a striking resemblance to Similar shaped Oak pieces.
As in every bit as compliant (yes it's been done) Be careful in what you wish for.. It may not please.
renetom
| posted on 11/10/13 at 07:50 AM |
Hi
They give you all the dims
Check out yours, its easy enough.
good luck.
TimEllershaw
| posted on 11/10/13 at 08:02 AM |
I'm currently replacing wishbone bushes on my car, so have done quite a bit of reading and researching. This is quite interesting :
Wishbone Bushes
http://www.teenagecancertrust.org/
Minicooper
| posted on 11/10/13 at 09:38 AM |
I don't know if these will fit either, but the bush is rated at 80 shore which means they are soft in comparison to the rock hard 90 shore which
is the normal material. I have some in the garage and they are quite flexable
[Edited on 11/10/13 by Minicooper]
