midlifecrisis
| posted on 25/10/04 at 10:15 AM |
speedo cable
Hi All ! I read another post re availability of a 90 deg. speedo drive g/box (£54) Does anyone know another way of doing this cheaper ? Also ,using a
1300 cc g/box,the cable is FAR too long . is there another vehicle that has a shorter (cheap)cable alternative? ROD
timf
| posted on 25/10/04 at 10:43 AM |
try http://www.speedycables.co.uk/
any cable any end made up to order
midlifecrisis
| posted on 25/10/04 at 01:12 PM |
Thanx for that ,I use speedy cables a lot for stuff. Just wondering about the 90 deg drive though?
paulf
| posted on 25/10/04 at 10:09 PM |
You could drill a hole in the tunnel and run the cable across the drivers floor and then up the chassis rail to scuttle, secure it with a couple of P
clips and cable ties. I did this as a temp measure whilst building my car and have never got around to changing it as it works perfectly
Paul
mangogrooveworkshop
| posted on 26/10/04 at 12:59 AM |
Citroen club had em at the back of the Jager instruments. Saw some on the EBAY AUSTRALIA a whileback.
cheers paddy
[Edited on 26-10-04 by mangogrooveworkshop]
midlifecrisis
| posted on 26/10/04 at 08:36 PM |
Paul I thought about doing that , but have now shortened the inner and outer cable ,and got a reasonable radius on it up against the tunnel . I f it
breaks again I'll try your way .
