pekwah1
| posted on 22/6/17 at 01:16 PM |
IVA brake warning light
Hi guys,
For the brake fluid/handbrake light on the dash - I read somewhere that the symbol has to be ON the warning lamp, not next to it for example.
I have small 6mm lights for my warnings, so couldn't put a symbol on it very easily.
Basically is this the case or will I be ok with it next to the light?
gremlin1234
| posted on 22/6/17 at 01:38 PM |
I think it can be adjacent to the light.
iva manual section 33 Identification of Controls
quote: Where provided Identification of Controls, Tell-tales and Indicators;
1. Must be clear so not to cause confusion.
2. Must be on or as close to the controls, tell-tales and indicators as possible as not to cause confusion.
3. Must stand out clearly from the background.
EDIT
but then checking further
that is only for the optional tell tales
Identification of certain controls, tell tales and indicators is mandatory and is covered in other relevant sections. This section only applies to
optional identification where provided.
[Edited on 22/6/17 by gremlin1234]
loggyboy
| posted on 22/6/17 at 03:49 PM |
Might fall down to interpretation.
But the wording is:
16. It must be possible to check the fluid relative to the manufacturer’s specified minimum level on all brake fluid reservoirs by the actual fluid
level being visible through a transparent section of the reservoir, with the minimum level marked permanently on to this section. As an
alternative, a red warning lamp (see Figure 1) must be capable of illuminating when the reservoir fluid falls to the minimum level.
And this is figure 1:
So to me points that it must have that symbol.
I would fit a correct one in a temp location that can be removed and replaced with your preferred 6mm lamp after.
Mistral Motorsport
gremlin1234
| posted on 22/6/17 at 04:14 PM |
But the wording is:
I agree,
or fit a transparent reservoir
loggyboy
| posted on 22/6/17 at 06:52 PM |
Yep, and the requirement for the warning light to double as a pressure loss warning is covered by.
The hydraulic system failure warning lamp must be secure, operational, visible during daylight and darkness from the driving
position, id entifiable (i.e. labelled in a recognised form see figure 1 for an example) and fitted with a “test facility” that
enables its operation to be checked from the driving position without opening the reservoir.
Does state it can simply be labled and only suggest figure 1 rather than requiring it.
Mistral Motorsport
