matt80
| posted on 17/1/18 at 05:31 PM |
MOT fail - ball joint cover
Evening all. My Locost failed the MOT due to a worn ball joint dust cover?! Does anyone know where I can get a replacement?
Many thanks for any help
obfripper
| posted on 17/1/18 at 05:41 PM |
Eurocarparts do a mixed sizes box for 5-10 quid that should do the trick.
Dave
matt80
| posted on 17/1/18 at 05:48 PM |
Cheers Dave, thanks.
SJ
| posted on 17/1/18 at 07:15 PM |
I had the same on a track rod end and just bought a complete new pair they as were so cheap.
steve m
| posted on 18/1/18 at 07:54 AM |
ebay is your friend,
https://www.ebay.co.uk/itm/2-X-High-Quality-Rubber-15-30-Dust-Cover-and-Ball-Joint-Boots/252487071188?epid=1590029382&hash=item3ac966f5d4:g:8dYAAO
SwaB5XqNYX
| posted on 18/1/18 at 11:17 AM |
Ditto - just replace the complete joint! MoT passed and any potential damage or wear removed from the vehicle.
| posted on 18/1/18 at 06:13 PM |
A little tip for fitting replacement ball joint boots that have a spring type clip on the bigger diameter, use 2 small lengths of brake pipe over the
ends of the clip for extra leverage and to cover the sharp ends.
matt80
| posted on 18/1/18 at 06:17 PM |
Thank you
