omega 24 v6
| posted on 20/5/05 at 09:24 PM |
cortina bottom ball joint
Am looking for a pdf or cad drawing of the bootm ball joint and upright/ top ball joint assy. have done a search but can't seem to find what
i'm looking for.
flak monkey
| posted on 20/5/05 at 10:59 PM |
I have a cortina 'upright' (actually its more just a stub axle and ball joint centres) to use as geometry. I assume that the geometry is
right, its based on someones 2d drawings and I created a 3d model. It lacks a lot of detail as you can see and there are no tapers in any of the
holes.
Dont have any ball joints though Im afraid.
You can download a copy of it from my website (ProD format). Or if you do want a copy in a different format (IGES) then I can provide you with one.
Sera
http://www.motosera.com
omega 24 v6
| posted on 21/5/05 at 09:54 AM |
cheers flak monkey but i'm still on autocad 14 2D
flak monkey
| posted on 21/5/05 at 10:40 AM |
In that case, how about the drawing i based my model on? You should be able to redraw it from that. (apologies about size).
[Edited on 21/5/05 by flak monkey]
Sera
omega 24 v6
| posted on 21/5/05 at 10:49 AM |
Now that i can do something with
thanks a lot i'll just have to convert to metric but.
flak monkey
| posted on 21/5/05 at 11:13 AM |
Can't you switch autocad between metric and imperial? I know I can switch ProD and solidworks, but I havent used AutoCad in a very long time!
Sera
