<<  1    2  >>
New Topic New Reply
Author: Subject: Keeping weight down in a build
MattCraneCustoms
posted on 18/12/06 at 08:56 PM Reply With Quote
Hi all,
Just read the thread about the weights of cars. Thought I would make a follow up thread - What have people done to keep their weight down in cars? Whats good and what isnt? Should be a useful thread for people wanting the most from their car.
Regards
Matt
P.S. I've only just started a build so can't really add anything!! Aluminium sheet instead of steel perhaps?
matt.c
posted on 18/12/06 at 09:00 PM Reply With Quote
Im going on a big diet!
zxrlocost
posted on 18/12/06 at 09:01 PM Reply With Quote
minimum interior
smaller wheels
no windscreen and with a bike engine should see you inbetween 430kg and 490kg
posted on 18/12/06 at 09:07 PM Reply With Quote
First thing to do is to ditch the car engine and get a lightweight bike engine. Second place to look and start saving weight is on the unsprung and rotational mass ie, wheels and tyre combination, brake discs and calipers and uprights. You can also save some weight on your choice of diff and driveshafts. The list goes on and on.............
Phil
Danozeman
posted on 18/12/06 at 09:12 PM Reply With Quote
Light weight battery will loose a bit more.
Light weight seat., No passenger..
Visit the lav before you go out for a drive
Dan
dave r
posted on 18/12/06 at 09:27 PM Reply With Quote
me and you both ;p
Volvorsport
posted on 18/12/06 at 09:43 PM Reply With Quote
minimum amount of wiring and dials , no carpets , interior etc.
keeping your rolling stock as lightweight as possible , soild discs etc , single piston calipers .
single gel coat and woven roving GRP , pretty cheap lightweight car .
www.dbsmotorsport.co.uk
getting dirty under a bus
smart51
posted on 18/12/06 at 09:51 PM Reply With Quote
Lose the pinto
lightweight wheels
solid discs not vented
CFRP bodywork instead of GRP
thinwall T45 steel for the chassis
smaller fuel tank
unpadded seats
no boot box
cutting off the excess length from the suspension bolts will save a kilo.
I've done none of these, except for the pinto.
fesycresy
Carbon fibre floor / rear panels / body work, muffet diff, magnesium 13" alloys, titanium bolts.
My ar*e, now stop dreaming and learn to drive faster
mark chandler
posted on 18/12/06 at 09:52 PM Reply With Quote
Round tube, small wheels, Ali floor and panels, bike battery, engine & dials.
If you pick it up and it feels heavy put it down and look for a lighter item.
Stength is in design, lots of triangles not thick lumps of metal !
Even simple things like using correctly sized bolts makes a big difference when added up.
Regards Mark
chrisg
posted on 18/12/06 at 10:39 PM Reply With Quote
This reminds me of the classic "Sevens" list topic about saving weight.
To summarise, men with necks like birthday cakes were disscussing wether it was worth drilling the centres out of bolts to save a quarter ounce.
Eat less pies.
Chris
iank
posted on 18/12/06 at 11:12 PM Reply With Quote
As said previously rotational weight is the 'best' kind to lose.
Proper racing lightweight wheels in a small size probably 13" [i.e. not halfords budget 18" ]
Decent lightweight tyres, do some research.
Solid discs rather than vented.
Also
Alloy calipers
For bonus points put the engine in the boot to avoid the penalty of the driveshaft and separate diff/gearbox casings.
posted on 19/12/06 at 07:51 AM Reply With Quote
me and you both ;p
And me! I'm not going to worry about the weight of my car until I've reduced the weight of the nut holding the wheel...
martyn_16v
posted on 19/12/06 at 09:32 AM Reply With Quote
Eat less pies.
Bwahahahahahahhaaaaaaa
I would suggest driving naked as a weight saving exercise, but the sight of a fatty rippling away in the wind (think Clarkson in the Atom, but oh so much more disturbing) is probably not one anyone else wants to ever experience. Ever
[Edited on 19/12/06 by martyn_16v]
posted on 19/12/06 at 09:40 AM Reply With Quote
The circumference of a fat backside
Is the formula pie/arse squared? Apart from the fitting solid disks which will actually be cheaper every other option apart from the diet seems to be very expensive. What about leaving the brakes off, that should save a bit, and put IRN-BRU in the radiator, the bubbles will weigh less than liquid. Shave your head, have your teeth out and any bits you can do without could be removed, come on how long is it since you used it and it just looks silly dangling there. My mate lost 2 stone when he had his leg off, how dedicated are you?
posted on 19/12/06 at 10:53 AM Reply With Quote
1. don't paint the body panels.
2. drive without alternator; you'll need to figure out how far the battery on its own will take you (not a good for long road journeys).
3. use a bus system for the electrics with chip control for the lamps to minimise amount of wire used.
[Edited on 19/12/06 by 02GF74]
Syd Bridge
posted on 19/12/06 at 10:55 AM Reply With Quote
Eat less pies.
Chris
I'm trying to lose 20kg's from my racecar build, -----------mainly from around my gut! And only three months to do it. It's gonna be a starvation Chrissy for me.
Cheers, ( Mines a fizzy water )
Syd.
Jasper
posted on 19/12/06 at 11:21 AM Reply With Quote
Decide what you want to use the car for first - if it's track blaster then go the mega lightweight route - if you want an all weather long distance machine then think again......
Confused but excited.
posted on 19/12/06 at 11:53 AM Reply With Quote
Eat less pies.
Chris
I thought the purpose of making the car lighter, is to get the performance without forfeiting the pies!
posted on 19/12/06 at 12:09 PM Reply With Quote
Syd.
I've managed to lose 14kgs from my car's all-up weight - another 7 or so to go... but I can't raise the enthusiasm!
hughjinjin
posted on 19/12/06 at 03:03 PM Reply With Quote
weight reduction
some food for thought on keeping weight down. The most important areas for weight reduction are in unsprung weight. The lighter the overall weight, the greater the effect of the unsprung weight on the handling of the car.
One of the most overlooked areas for weight reduction by amateur builders is also one of the most important.I'm talking about wheels and tyres.
On my car, an Alfasud Sprint, the standard wheels and tyres (5.5x14 and 185/60) weigh in at 18kg a corner. Replacing them with old 7x13 Allycat rally specials which cost me a tenner each and a set of 7x21 Avon acb10s (part worn 65quid a set delivered) lost 7kgs a corner. If you also consider that because they are rotating they effectively add another 1/4 of their weight to the rest of the car it adds up to carrying an extra 35 kgs or so or to put it another way the weight of an extra gearbox!
I had no idea that there was such a weight difference until I put them on the bathroom scales so think about that before buying alloy hubs to save 1kg a corner!
smart51
posted on 19/12/06 at 03:45 PM Reply With Quote
Originally posted by hughjinjin
If you also consider that because they are rotating they effectively add another 1/4 of their weight to the rest of the car ... so think about that before buying alloy hubs to save 1kg a corner!
But hubs rotate too!
hughjinjin
posted on 19/12/06 at 04:02 PM Reply With Quote
smart arse
my point is that it is better spending your money on reducing the weight of the wheels and tyres than on the hubs because there is much more weight to be saved
posted on 19/12/06 at 04:27 PM Reply With Quote
Re the diff. Go for a freelander diff. Its lighter than a standard Ford item.... Not as cheap though.... Quaife do a LSD for it too which is certainly a wallet-lightening exercise...
Otherwise it's just ali floor panels, bike engine , alloy uprights / callipers etc as previously mentioned.. Nicad battery (or at least motorbike battery)....
Drill f'ing big holes in the passenger footwell firewall and plate over the ali (have you seen how thick the metal is sometimes!?!) or if you're DIYing the chassis only put battleship grade steel on the driver side firewall for the pedals.
If you want to go really light get drilled and grooved brake discs... When the cracking around the holes gets really bad and the disc explodes they don't way anything
C10CoryM
posted on 19/12/06 at 06:40 PM Reply With Quote
Anyone know how much weight IRS saves overall? Obviously the unsprung weight is the primary reason, but wondering how much heavier a solid axle would be.
Cheers.
"Our watchword evermore shall be: The Maple Leaf Forever!"
<<  1    2  >>
New Topic New Reply
