adriane
| posted on 6/2/07 at 08:43 PM |
Hayabusa Speedo sensor pick up
Hi There
I have finished my build but cannot get the speedo to work. I have a Hayabusa engined MK Indy and am using the bike clocks. I have carried out several
checks and it points to the pick up sensor. Any got one as I did not want to spend £65 and find out it is not that. I am willing to pay for it and of
course the postage.
Adrian
rayward
| posted on 6/2/07 at 08:45 PM |
is it a three wire sensor?.
do you know if its PNP or NPN switched??.
Ray
adriane
| posted on 6/2/07 at 09:44 PM |
Yes it is 3 wires. One wire is earth/negative, the second 12v+ and the third is the pulse return. I do not know if it is PNP or NPN
yorkshire-engines
| posted on 7/2/07 at 10:55 AM |
re speed sensor
Hi iv got a sensor if you need one to try
also the sensor needs the 4 pin trigger thats on top of the sprocket nut to work have you got that in place
cheers malc
