ReMan
| posted on 2/5/07 at 11:18 PM |
Trailer advice
Will my Indyblade stand any chance of getting onto this sort of trailer, bearing in mind the way the bed is made with lots of cross bars. More to the
point would I ever get it off, without a reverse gear?
Or would I have to winch it on backwards , then drive it off?
Or could I cover the bed with plate or board to make it easier, or do I keep saving for a
tilter?[img]http://locostbuilders.co.uk/upload/a550693-00e5_1_b[1].jpg[/img]
robertst
| posted on 3/5/07 at 01:28 AM |
looks like those rusted bits in the middle serve as a ramp? it looks small to me... anyways it shouldnt be such a problem to push/drive the car on and
off the ramp... you can always connect a winch to the end of the ramp to get the car on as you said...
it would be very helpful to rivet some plates where the wheels go, maybe that galvanized checkered plate? what was it called? diamond something....
[Edited on 3/5/07 by robertst]
Tom
Richard Quinn
| posted on 3/5/07 at 05:43 AM |
The only thing to watch is the angle formed by the ramps/bed when loading / unloading. Short ramps and a reasonably high bed will lead to bottoming
out.
I have fairly short ramps on my trailer but it also has drop down supports at the back which means that by detaching the trailer from the car,
dropping the ramps and jacking the front up on the jockey wheel (and then dropping the rear legs to suit) I get a fairly smooth (and stable)
transition from ramp to bed to get my grasser on.
ReMan
| posted on 3/5/07 at 06:55 AM |
Hmmm, did'nt explain very well. I mean the bits where the wheels run and wether they would be to "bumpy?" for a light car and
impossible to push on/off?
TimC
| posted on 3/5/07 at 08:44 AM |
Be fine unless you're very weak indeed.
ReMan
| posted on 3/5/07 at 10:34 AM |
Good point about the angle for thepoint of grounding and for me being strong enough!, particularly if I did have to push it on. I am hoping really for
1 man operation, so I may at least need a winch?
house21
| posted on 3/5/07 at 04:10 PM |
Hello guys
I have in mind to get trailer and can you advice me what size should I get?
I drive a 4x4 Vitara
ReMan
| posted on 3/5/07 at 08:00 PM |
Er, What do you want to put on it?
pjavon
| posted on 3/5/07 at 08:12 PM |
I made a similar style trailer for my car, drive it on and lift the front of the trailer a bit with the jockkey wheel, with it still attached to the
car, and one little shove and it should roll off. I did have to alter the cross member at the back to miss the sump though but now works fine. Hope
this helps a bit
  TRAILER
Always keep a big hammer and a condom in your toolbox, if you can't fix it with the hammer
ReMan
| posted on 3/5/07 at 10:05 PM |
That's very smart. I thing on the strength of it the one I was lookingat is no good, 18" high and ramps shorther than that, it's
never going to make it on.
I qute fancy making my own , but I think I lack time and a flat surface, let alone plans!!
ThAnks
COLIN
