<<  1    2  >>
Author: Subject: Brake pipes
Stuart_B
posted on 8/1/08 at 05:14 PM Reply With Quote
Brake pipes
hi, i done my rear brake pipes and i was wondering would i be allowed for the sva?
Stuart_B
posted on 8/1/08 at 05:15 PM Reply With Quote
And this
Stuart_B
posted on 8/1/08 at 05:16 PM Reply With Quote
And one more
matt_claydon
posted on 8/1/08 at 05:32 PM Reply With Quote
Looks fine to me, as long as the flexis don't rub on the chassis or wishbones.
[Edited on 8/1/08 by matt_claydon]
RazMan
posted on 8/1/08 at 05:33 PM Reply With Quote
Can't see anything obviously wrong there..... apart from the humungous pics
[Edited on 8-1-08 by RazMan]
Raz
let me guess, Santa brought you a new 10 Mega pixie camera and a utlra wide LCD screen
look ok to me although black P-clips are the fashion for 2008.
NB some SVA centres have been known to fail exposed braid on the hoses - sharp edges would you believe? - to play it safe, wrap some convoluted tubing over them with cable ties.
matt_claydon
posted on 8/1/08 at 05:34 PM Reply With Quote
No rules for sharp edges amongst the rear suspension!
Stuart_B
posted on 8/1/08 at 05:47 PM Reply With Quote
Sorry about the big picture, thank you for the quick replys.
Thank you
Stuart
indykid
posted on 8/1/08 at 06:02 PM Reply With Quote
what have you done with the other end of the flexi at the upright/wheel end?
tom
Stuart_B
posted on 8/1/08 at 06:12 PM Reply With Quote
i have done this
picture below:
matt_claydon
posted on 8/1/08 at 06:43 PM Reply With Quote
The hub end needs to be supported where it meets the flexi, else eventually the copper pipe will fatigue and split.
Avoneer
posted on 8/1/08 at 06:45 PM Reply With Quote
The union in the last pic between flexi and solid needs a solid mouting as well.
Pat...
Avoneer
Damn, beaten to a reply again.
Pat...
Stuart_B
posted on 8/1/08 at 06:50 PM Reply With Quote
so i will have to weld a bracket on to the hub, what size steel will i need to use, has any one got any pics of the bracket??
thank you
Stuart
posted on 8/1/08 at 06:57 PM Reply With Quote
I made a bracket that is held in place by one of the suspension bolts and made the metal pipe to suit.
posted on 8/1/08 at 07:17 PM Reply With Quote
They can fail braided flexy pipes if they're rubbing against other things, like brake pipes, electrics, or similar. The braiding can work like a file against other surfaces!
John Bonnett
posted on 8/1/08 at 07:42 PM Reply With Quote
I used small Spirap for wrapping the braided flexibles from Car Builder Solutions and they went through SVA without the tester batting an eyelid.
John
bigbird
posted on 8/1/08 at 08:05 PM Reply With Quote
my bet is that little yellow bung in the T piece will leak.
Stuart_B
posted on 8/1/08 at 08:57 PM Reply With Quote
i am have not done the other side yet i need a brake flaring tool, so i can shorten it.
stuart
vinnievector
posted on 9/1/08 at 07:27 AM Reply With Quote
brake pipes
Picked up two things you might want to look at ,as your pipe gose over the diff support brackets you might get some chaffing their ,also at the wheel hub end where you have your solid brake pipe from your wheel cylinder to your flexi hose there is no support braket .
attached some picks of my set if it helps Rescued attachment Picture 219.jpg
tks
posted on 9/1/08 at 06:43 PM Reply With Quote
also its best to give each side on the T the same lenght!
it wil result in the same pressure losts both rear wheels wil act more the same while unther braking.
Tks
RazMan
posted on 9/1/08 at 06:52 PM Reply With Quote
It makes no difference whatever length the pipes are - you are still moving the same volume of fluid so the pressure is still the same.
Raz
NS Dev
posted on 10/1/08 at 11:31 AM Reply With Quote
two points, already covered but:
1) bracket in 3mm ish steel to support the flexi to copper junction near the drum (weld a bit of 3 mm strip on or hold it with a bolt head)
2) flexi looks like its rubbing the chassis?? If it is it will fail. Just slacken the end fittings and rotate the flexi to a safe position and lock them up again.
DarrenW
posted on 10/1/08 at 12:11 PM Reply With Quote
Why cant the flexy be screwed straight into the wheel cylinder?
Stuart_B
posted on 10/1/08 at 02:10 PM Reply With Quote
so 3mm steel is need for the brackets, and if the flexi is touching the chassis,can i wrap something around the flexi??
Stuart
<<  1    2  >>
