New Topic New Reply
Author: Subject: Bike throttle cable - oil or no oil?
posted on 8/4/08 at 06:37 PM Reply With Quote
My bike carbs have a bike throttle cable from the pedal. It's got a liner, but I was wondering if I should oil it.
It's got a little bit of 'sticktion'- nothing serious, but it would be better if it ran a little freer.
NeilP
posted on 8/4/08 at 06:38 PM Reply With Quote
White grease?...
If you pay peanuts...
Mentale, yar? Yar, mentale!
Drive it like you stole it!
posted on 8/4/08 at 06:40 PM Reply With Quote
It's got fixed ends, so if it can't be dripped in from one end, it ain't going to happen!
r1_pete
posted on 8/4/08 at 06:47 PM Reply With Quote
Right or wrong I oil the bike cables, I rip the corner off a plastic bag, pass it over the nipple, tape it to the outer cable, hang it with a teaspoon of synthentic in it to drain through. In my veiw as well as lubing it keeps rust at bay.
posted on 8/4/08 at 07:12 PM Reply With Quote
Use to have a bike cable oiler , bit like a bike pump witha removable end cap and seal that fitted round the cable , the other end had a screw in plunger . Place over end of cable, fill with oil and pressurise to force oil through.Haven't seen it in years though
posted on 8/4/08 at 07:18 PM Reply With Quote
I used to have one of those! Got more oil on me than into the cable. I've also tried to make a funnel out of plasticene, which was amazingly messy after a while!
The plastic bag trick sounds useful - might have to have a play...
Simon
posted on 8/4/08 at 09:56 PM Reply With Quote
It'll depend on type of cable, though it's a long time since I needed to know about such things.
If it's steel cable and steel liner then oil. If it's got plastic liner, I doubt it, but check with maker.
Simon
worX
posted on 8/4/08 at 10:41 PM Reply With Quote
Get yourself to a local bike garage, they'll have a "clamp-able" steel block that has an inner feeder to the cable from the sleeve. I'm sure a few nice words would let you have a go yourself for free if you fetched you'r own WD!
DarrenW
posted on 10/4/08 at 08:16 AM Reply With Quote
To flip this question around - what happens if you oil cables that shouldnt be oiled? All i can think of is that some cables dont need to be oiled but if you do then nothing bad will happen (maybe ptfe lined??).
posted on 10/4/08 at 08:35 AM Reply With Quote
If it has a nylon liner the nylon can swell up and cause the cable to get tighter.
posted on 10/4/08 at 09:11 AM Reply With Quote
That was one of my concerns - and why I asked the question in the first place!
PAUL FISHER
posted on 10/4/08 at 09:38 AM Reply With Quote
This is what happened to mine,ended up removing the liner,it works great now
New Topic New Reply
