tjoh84
| posted on 2/8/08 at 10:25 PM |
would these wheels fit locost
as above will they fit book locost
7x15 - 4x108 - ET:35
tjoh84
| posted on 2/8/08 at 10:26 PM |
or what the best et thanks
worX
| posted on 3/8/08 at 04:55 AM |
I think you are probably running an offset of ET18.
t.j.
| posted on 3/8/08 at 06:19 AM |
These will be more inwards due the ET (17mm) but also cause the 7J. So be carefull.
Maybe you could use "spacers" to fill out to ET 18? But then the wheel will come more outwards.
I'm using 6J ET 40, but have IRS and infront i will use spacers to keep ET19.
So you can mount everything but.....
Danozeman
| posted on 3/8/08 at 10:21 AM |
If your running escort axle im sure they will touch you trailing arms.
Dan
tjoh84
| posted on 3/8/08 at 02:47 PM |
cool thanks for the replys
