C10CoryM
posted on 20/9/08 at 08:37 PM |
Well, SOME of it fits under the bonnet...
Not much point to this post I'm afraid.
Looks like I will be able to fit the valve covers under the bonnet. I guess there is no chance of this car being subtle anymore though .
Have a solid days work then the chassis is off to the welder for the bulk of the welding. Then it will be a rolling chassis (and technically a
car..... yay!)
"Our watchword evermore shall be: The Maple Leaf Forever!"
Howlor
| posted on 20/9/08 at 08:39 PM |
Will a periscope pass SVA?
RichardK
| posted on 20/9/08 at 08:52 PM |
Do they have therapists in Canada I think you need help
Will be so when its finished
Rich
Gallery updated 11/01/2011
locoR1
| posted on 20/9/08 at 09:04 PM |
Thats going to be awesome i like it!
Check out my CB500T Cafe Racer build diary
robertst
| posted on 20/9/08 at 10:19 PM |
you can make it look like a veyron, have the supercharger come out of the bonnet... that would look great...
RK
| posted on 21/9/08 at 02:38 AM |
Man, I thought my Nissan CA18DET was big!
graememk
| posted on 21/9/08 at 07:11 AM |
my ca18et is tiny
Ivan
| posted on 21/9/08 at 07:16 AM |
Looks really . What is the HP? Boy are you going to have fun with traction - I think you can do away with the gearbox (save a chunk of weight)
and just have a clutch or torque converter.
Only thing - I would have used 38X25 or 50X25 for the lower rails in the engine compartment - but maybe you've done some additional
triangulation that I can't see from the photo
blakep82
| posted on 21/9/08 at 01:09 PM |
are you going to have one of those drag style intakes, with the 3 red butterflys on top, sticking out the bonnet?! that would be awesome!
[Edited on 21/9/08 by blakep82]
________________________
Mave
| posted on 21/9/08 at 02:03 PM |
You mean like this?
Humbug
| posted on 21/9/08 at 05:36 PM |
You could raise the side rails by 12" all round so a normal bonnet would fit... only thing is, you would then need a bar stool to sit on to see
over the top
C10CoryM
| posted on 21/9/08 at 06:11 PM |
Thanks guys.
No SVA here in Canada so I should be fine that way. The therapists have tried, they gave up years ago.
The engine isn't as big as it looks in the picture. I'm hoping to have only about 1/2 the blower sticking out of the hood. The throttle
body is on the rear so no big hood scoops .
The power level really isnt that high. In stock form they make 240bhp with a healthy 280ft/lbs. Once I am used to the car, I will probably bump up
the boost and cam it. Most guys get about 300bhp and 300ft/lbs. Most guys with these engines have heavy cars and want torque. Not sure what happens
when you build for power instead. Will find out I suppose.
There is extra triangulation that is hard to see. The engine mounts are tied into the footwell bulkhead. Also is some bolt in bracing that
isn't done yet. It should be stiff enough. I really don't expect to have enough traction to twist things too much.
If I could only get rid of this damned cold I would have the thing ready to go to the welders today . Oh well, one more week.
Cheers.
