ID required brake pressure switch / thread.
GregSL75 - 2/9/10 at 08:59 PM
I have this type of pressure switch fitted:
Fitted to this type of t piece:
The switch has failed so I bought a new one as above (listed as for a mini) but the thread is too large.
I've taken some measurements of the old switch and the thread is a taper thread, max diameter is just under 3/8" and the pitch is approximately Metric 1.0 (only have a metric thread gauge) Anyone know what this corresponds to?
The new switch is approx 1mm larger diameter and a similar thread pitch..
Mal - 3/9/10 at 11:57 AM
The 2 threads used are 3/8"x24TPI UNF and M10x1 metric.
The tapers complicate things a little but the metric thread is about 0.5mm larger in diameter. A classic Mini is likely to need the UNF thread.
Mal
GregSL75 - 3/9/10 at 12:47 PM
Looks to be the 3/8 UNF one then as 24 tpi is just under 1.0 thread pitch from what I can tell from google. (25.4 tpi would be 1.0)
I'll have a look about and see if I can get one from the local motor factors.
Thanks!
