I have tried two sets of 5JJ R1 clocks:
Original set: Doesn't display correct speed (always 0mph) on the LCD display. But no error codes.
Newer set: Displays speed, but has an 8000rpm self diagnostic needle bounce every few seconds (relates to fuel sensor issue - first set of clocks
suggests the fuel sensor is fine).
Will either or both be an MOT failure? I'd rather get the car on the road asap so I can have a few more days driving the damn thing, and I can
live with the needle bounce for the time being.
James
Speedometer and rev counter are not part of class 4 MOT test
Neither are an issue
Oh jeez that's annoying, I had assumed the speedo not working was a certain fail - I hadn't gone for an MOT for that very reason! Time to book an MOT on a dry day.
Speedo not working was brought into the MOT in 2012. Tacho isn't part of it though.
"Reason for Rejection:
1. Speedometer not fitted.
2. Speedometer incomplete, clearly inoperative or the dial glass broken or missing.
3. The speedometer cannot be illuminated."
The broken glass only applies if it is a danger, could foul the pointer or could be misread as the pointer.
Interestingly:
"A Tachograph is an acceptable alternative to a speedometer providing it satisfies the requirements of this inspection."
[Edited on 5/10/15 by SteveWalker]
Realistically, a tester won't ever move the car quickly enough to know whether the speedo is working or not anyway. Or at least they shouldn't.
They may well do with a kit-car. My local place decided that the low ground clearance was a risk with their brake rollers, so took it out on the road
with a deceleration (Tapley?) meter.
Also commonly used for permanent 4-wheel drive vehicles that should not be tested on normal brake rollers.
Originally posted by SteveWalker
They may well do with a kit-car. My local place decided that the low ground clearance was a risk with their brake rollers, so took it out on the road with a deceleration (Tapley?) meter.
I bet that was an excuse to have a ride in your car.lol![]()
I'll put the clocks in with the working speedo just in case.
My thoughts were that often something which is fitted to a car must be working. I do get the correct rpm for about 2 seconds every 5 seconds or so, so
that's kind of working? And the error relates to a fuel level sensor which I highly doubt is tested anyway.
