Don't try this at home!
James - 19/1/04 at 12:22 PM
http://www.wiseguysynth.com/larry/day.htm
Check this out. If you click the picture it loads a video that's well worth seeing! It's only 9 seconds so should be ok even for dial-up.
If it wasn't for all the explanantion I might think it a fake.
James
liam.mccaffrey - 19/1/04 at 12:33 PM
that is pretty cool,
re: don't try this at home
there is a way where you can make proper lightning in your microwave, I cant remember how to do it off hand.
Does anyone know?
(its not just putting metal in it)
theconrodkid - 19/1/04 at 12:49 PM
looks like me welding
liam.mccaffrey - 19/1/04 at 12:55 PM
apparantly wire wool sprinkled with carbon dust will produce ball lightening effects! which are meant to be quite good!
ijohnston99 - 19/1/04 at 01:51 PM
An old CD makes lightening too when placed in the micro.
Disclaimer: Only a complete idiot would actually try this, and I accept no responsibility for the consequences
[Edited on 19/1/04 by ijohnston99]
JoelP - 19/1/04 at 03:20 PM
light bulbs light up in the micro, again though, not very clever if it goes poop!
stephen_gusterson - 19/1/04 at 04:39 PM
small flourescent tubes might..... if you hold one anywhere near one of those plasma ball thingies, they glow, I have done it
atb
steve
kingr - 19/1/04 at 05:10 PM
If you cut the top off a foil lined juice carton and put that in the microwave you can get some lovely lightning effects.
Kingr
blueshift - 19/1/04 at 05:41 PM
I must be a complete idiot then, I've done it several times (mostly with NT CDs at work) with no ill effects to myself or the microwave (the CD, however, does not survive the operation intact)
Deckman001 - 19/1/04 at 07:23 PM
As I only have the one Micro jobby, do any of the above tricks adversly affect the cooker, as i don't want to sample the Wifes wrath !!
Jason
David Jenkins - 19/1/04 at 10:18 PM
The risk of injuring your microwave is fairly high!
These tricks are best done when you've just bought a new one, and the old one's still working...
rgds,
Roland - 19/1/04 at 10:30 PM
Here's todays recipe.
Take one glass, put small amount of water in, then place one 60 watt bulb in glass.
Place on turntable in microwave, close door and start, watch it light up. We used to do this to demonstrate mirowave ovens to customers. Be careful, not to leave in microwave too long or........BANG!
Roland
ps
I take no responsibility for anyone getting injured etc, etc
Deckman001 - 19/1/04 at 10:34 PM
Many thanks David, will wait a bit longer to try it then
Jason
blueshift - 20/1/04 at 03:59 AM
deckman, I have done the CD trick several times in various microwaves without them suffering any damage. it doesn't explode or anything. You see the effect briefly after a couple of seconds, then nothing else interesting happens. stop the microwave once you've seen the effect or little holes start burning in the CD (not as pretty, and nasty smell).
I've never heard of this damaging a microwave, but don't blame me if you manage to break yours
Peteff - 20/1/04 at 10:19 AM
Slice a green grape almost in two and open it so it just holds togetherwith a little bit of skin. Microwave it on full power and the joining piece arcs and its safe. Not quite as spectacular as the clip but it amuses me.
yours, Pete.
tadltd - 21/1/04 at 12:31 AM
how the f*ck did you find out about the 'grape thing'??!!!
(off to buy grapes in the morning...)
Steve.
steve m - 21/1/04 at 01:32 AM
you lot really do need to get out into the garage more often
you are all F*****g mad
I have a spare microwave!!!
Deckman001 - 21/1/04 at 08:32 AM
Not for much longer i suspect steve !!
Jason
