We have a large double garage built into the side of the hill, I would imagine it was build around 1970-1980 it has breezeblock walls with an enormous
RSJ inside and a 2 foot thick reinforced concrete roof....
At present there is nothing on top of it. However the lawn above is much higher than the roof.
What I want to do is build a retaining wall allong the front of the roof and scrape the soil from the lawn onto the roof to level out the area.
A comercial structural engineering company that one of my friends works for has quoted £450 to do a site visit and write a report etc, but would
charge extra to redesign te roof etc.
Has anyone any experience of doing this sort of thing?
Do I need planning etc to move some soil onto the roof?
Any thoughts would be appreciated.
You’ll need some good damp proofing. Why is the roof so thick? Is it a nuclear bomb shelter or was it originally designed to be buried or had
originally been buried in the past?
How many garages have a 2 foot thick concrete for a roof anyway?! How much more concrete do you think you need???
[Edited on 8/9/09 by Mr Whippy]
astroturf?
just a thought...Osama bin laden may be using your garage as a bunker so take care going in alone
I assume the roof was intended to carry the load of soil but for some reason was never compelted... but I cant be sure the structure will be strong
enough....
I had thought about damp... A thick waterproof membrane on the roof, followed by a thin (ish) layer of concrete poured on a gradient to force the
water to flow off the burried roof... another waterproof membrane and then the soil, piled on top...
It would only be about 80-100cm deep... but thats quite a bit of weight!
Working on a typical double garage size of 5.5m x 6.7m, that would be roughly 60 to 75 tonnes of soil on there. If the roof really is 2' thick, there could already be more than 25 tonnes of concrete there. I would get a Structural Engineer to look at it first as, if it does come down, 100 tonnes of concrete and soil isn't something you will shift with a dustpan and brush.
Or 2 locosts (not pinto engined obviously).
Be Advised---Dont do it without a professional Engineer accessing the situation. Better to be safe than sorry.
simple first question - how much weight can a breeze block wall support?
Once you know that you'll have an idea if it can take the roof weight, seems a hell of a lot to a complete numpty like me!
This might be useful
http://www.livingroofs.org/
Planning wise you might get away with it under permitted development. Geotechnically speaking I have an engineer who works for me if you need advice.
Forget the grass it's a PITA it grows and needs cutting. Put a deck on it.
How do you know its reinforced?
Have you had a section cut out and looked inside?
Its not a case of how much can a breeze block support there are many types all with different strengths.
You don't know if the roof is only designed to support its own weight only
I too work in the construction industry I am not a structural engineer but an electrical consultant, I would confirm that £400-£500 plus vat a day is
a reasonable charge for a fully qualified consultant engineer personally I charge £400.00 plus vat per day.
Please, Please, get an expert to look at it.
Also take weeks of rain, 2 m snow and ice into account! It would be a pity if your bomb shelter caves in and crushes your 7!
