What do people use to clean up oil spills on the garage floor . I spilt oil from the filter on the nice clean concrete floor and would like to try and clean up the mess.
cement dust, cat litter box stuff, saw dust, all kinds of stuff really
Cement dust from the floor, newspaper, sand whatever's to hand as Blake says.
got a fluffy cat and a pole?
Blow torch!
cat litter works well for me.
i also have a carpet in the garage, so i just cut the section out and replace with another from the scrap heap
Kitty litter is ok as long as you don't try to use the pine wood based stuff, "Fullers earth" is what you need. However, cement is a lot more effective IME.
I used some sharp sand (hand it to hand in the garage). Soaked up the oil nicely. Though I suspect cement is best as that's what they use on race tracks...
If you paint your garage floor first then it pretty much just wipes up with old rags and doesn't soak in.
Use some washing detergent neat to get rid of the stain after you clean up if you are bothered about it. Scrub it in then rinse it off but it will fade eventually or get more added to it.
Spred kitty litter over the stain and rub over with a brick.
It grinds the litter and absords the oil.
