OMFG !
clairetoo - 24/9/09 at 08:18 PM
I had a bit of a fiddle with my car tonight - I found the other night that the timing wasnt moving as the revs rise , just sitting at 10 degree's `limp home' on the Edis
So......... tonight I had a look inside the megasquirt and found the jumper lead for the Edis had broken off..........two minutes with the soldering iron had that sorted (which of course required a `test` drive.............)
And.............OMFG it's piggin AWESOME !
I think I now have the full fat , super scary , tyre smoking beasty I have allways wanted !
Chilln` now with a JD'n'coke
blakep82 - 24/9/09 at 08:19 PM
had it always only been running on edis before?
BenB - 24/9/09 at 08:20 PM
Turned out well then. Go for the diet version for a little while then crack open the full fat when you're used to RWD.... Free power upgrade!
Ben_Copeland - 24/9/09 at 08:25 PM
coolio
McLannahan - 24/9/09 at 08:50 PM
Was it running in that mode at Stoneleigh? Remember you not being too happy with your run on the dyno?
clairetoo - 24/9/09 at 08:50 PM
It's always had the megasquirt/edis setup , but has never felt `right'
I have been looking at everything , checking everything , re-working everything..........for the last year or so..........but I just assumed the megasquirt was working properly
Having a proper ignition map running sure does make one hell of a difference
blakep82 - 24/9/09 at 08:56 PM
hmm, so must have always been broke then? awesome, glad it makes a big difference
clairetoo - 24/9/09 at 09:06 PM
I think it was - it made a measly 135 brake on the rollers , around 70 down on what it should have been
I think it now has the missing 70...........maybe more
omega0684 - 24/9/09 at 09:13 PM
i think im due a ride! glad to hear that you now have everything sorted! i have a job for you as well if your up for it!
clairetoo - 24/9/09 at 09:36 PM
No worries..........I may have to drive it around a bit (for mapping purposes , of course )
I always up for a bit of a job
McLannahan - 24/9/09 at 09:39 PM
Quality news then - good work!
Same project planned for Graham's now?
clairetoo - 24/9/09 at 09:52 PM
Hopefully Grahams will be running by Saturday afternoon - just gotta pick up the plug leads tomorrow afternoon , and a few little jobs to finish - then the obligatory `first start' video to shoot.............
omega0684 - 24/9/09 at 10:13 PM
if your still sorting grayham's car out then job that needs doing can wait, im in no hurry for it, i have loads to be getting on with! hi ho hi ho its off to the garage i go (not now though)
